Author Topic: 2 speed wipers wont "park"  (Read 772 times)
Offline 66RavenGTCoupe
« on: March 03, 2014, 01:28:45 AM »
Hi all,
Just finished a full engine bay restoration / rebuild on my 66 and went to check my lights, heater, radio and wipers and they all work as they should but my wipers do not go all the way down to the bottom of the wind shield like they are used to. Wiper motor is still the original. Any clues as to why?
__________________
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline Hipo giddyup
Re: 2 speed wipers wont "park"
« Reply #1 on: March 03, 2014, 10:49:34 AM »
   This might be elementary but I'll throw these out anyway. First, make sure nothing is binding the arm assembly under the dash. I had  speaker wires get caught up in the arm assmebly once, wasn't pretty. Secondly, did you remove the wipers from the windshield?? Perhaps they are in the wrong placement. I set mine when the motor stops, (no wipers attached), then place the wiper in a sort of level position. I never push them on all the way in case they need to be moved/readjusted again. You also dont want them slapping your drivers side window molding! ;)
« Reply #2 on: March 03, 2014, 04:31:38 PM »
All great advice but it ended up being one of the green wires with the spade connection coming loose! All fixed now. Thanks for your input though.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
