Author Topic: Vinyl Top Trim Question  (Read 11963 times)
Offline imbett
« on: February 21, 2014, 11:55:51 AM »
 I require help on vinyl top  My car has a small 1/4 inch trim between the top and the drip rail I need all info on
  1  does it go on before or after drip rail mouldings
  2  What type of tool or make do I need and they look like small pop rivets are needed ?????
  thanks  JOHN :)
« Last Edit: April 15, 2023, 06:07:07 PM by J_Speegle »
Re: Vinyl Top Trim Question
« Reply #1 on: February 21, 2014, 09:11:35 PM »
I would add the drip rail moldings after. Think of it this way- you get the top attached to the roof, pull and push the top into the drip rail depression and then, since all of the material needed is in place, you can trim the excess and install the drip moldings. Done the other way there is too great of a chance that you would run short of material
Don't know of any special tool - I've used a nylon window spoon or bar to push/tuck the top into corners like around the front or rear window depression. Us it more often for getting the head liner in place or helping weather strip around the windows in place - especially helping in the corners
Basically your looking for a blunt tool that can push the top material into the drip rail depression without tearing the material till the contact cement grabs. A couple radiused paint sticks tapped together would work in a pinch
The use of rivets to hold a strip in the gutter of the drip rail started in Oct of 1967 (early 68 production) and used 1/8" rivets to attach the strip
« Last Edit: April 15, 2023, 06:07:14 PM by J_Speegle »
Offline imbett
« Reply #2 on: February 22, 2014, 10:35:41 AM »
HI  I sure enjoy your help I am most concerned with getting the POP RIVET GUN into the small area and not marking vinyl   :)
« Last Edit: April 15, 2023, 06:07:21 PM by J_Speegle »
Offline imbett
« Reply #3 on: February 22, 2014, 10:39:36 AM »
I have a MARTIREPORT and it shows a production date of MAR 26 NOT AND EARLY DATE but it has it  JOHN
« Last Edit: April 15, 2023, 06:07:33 PM by J_Speegle »
« Reply #4 on: February 22, 2014, 12:45:12 PM »
A concern but there are many than have small profile heads and if you use it horizontally with the drip rail they will fit. With some caution and time you can do it
Not sure what this reference is to unless its the retaining strip. If so them a Mar 26th day would be almost 6 months after they started this practice according to Ford
« Last Edit: April 15, 2023, 06:07:41 PM by J_Speegle »
Offline imbett
« Reply #5 on: February 22, 2014, 04:27:26 PM »
I should never assume but   :I did as I read that as only early production SORRY but I sure like the help  JOHN :)
« Last Edit: April 15, 2023, 06:07:51 PM by J_Speegle »
Re: 1968 GT-CS Vinyl Top Question
« Reply #6 on: February 22, 2014, 07:14:48 PM »
No problem - I often read through posts too quickly and sometimes miss important words :(
Glad to help
Offline Oz390
« Reply #7 on: February 23, 2014, 03:44:16 AM »
Pop rivets go in from the underside, not in the channel.  That way the somewhat flush head is exposed on the underside, not the compressed stud end.  The stud end is covered by sealant in the channel.
« Last Edit: April 15, 2023, 06:07:57 PM by J_Speegle »
8R03S : 76A I 2A 15M 72 5 U
Offline imbett
« Reply #8 on: February 23, 2014, 03:30:45 PM »
Hi  Well that makes sense and as long as I have had this car I never thought it would install like that :) :)  THANKS  this a great site
Offline imbett
« Reply #9 on: February 23, 2014, 03:31:56 PM »
WHAT DO YOU USE AS SEALANT
« Last Edit: April 15, 2023, 06:08:13 PM by J_Speegle »
« Reply #10 on: February 24, 2014, 12:06:56 AM »
Pop rivets go in from the underside, not in the channel. ..........
Though I've seen them inserted from the bottom on fastbacks Ford's instructions and repair instructs show them being installed from the top down.
Here is a modified scan of the TSB (#1216) that illustrates the fix for earlier built car and the factory installation practice as described by Ford for the dealers, service managers and mechanics
« Last Edit: April 15, 2023, 06:08:21 PM by J_Speegle »
« Reply #11 on: February 24, 2014, 01:27:43 AM »
Only have Ford part numbers for the stuff so that is no help. If I recall correctly the stuff appeared to be a white or black silicon based material . Finished produce was very smooth and elastic
Other instructions I found in TSB article show applying masking tape along the top edge to work as a dam and provide a straight finished edge. Apply the sealer then peel back (horizontally to the drip rail) the tape before it firms up
« Last Edit: April 15, 2023, 06:08:34 PM by J_Speegle »
Offline Oz390
« Reply #12 on: March 02, 2014, 07:45:23 PM »
Can only say the original Vinyl roof '68's cars (one GTCS one S GT coupe) I have have them installed from below.  And that pic is a service note, for pre October '67 cars?  And not factory assembly info? Which would not even be relevant to the GTCS noted, which were built long after that... ???
« Last Edit: April 15, 2023, 06:08:41 PM by J_Speegle »
Offline franklinair
« Reply #13 on: March 03, 2014, 02:42:45 PM »
What is availability of the drip rail strip?
Neil Hoppe
« Last Edit: April 15, 2023, 06:06:50 PM by J_Speegle »
« Reply #14 on: March 03, 2014, 08:23:14 PM »
First welcome Neil to the site/forum - hope you find the information here useful in your concours related efforts
If you asking if they are available in reproduction form - I don't believe they are, so if needed you'll be looking for a donor car
« Last Edit: April 15, 2023, 06:06:58 PM by J_Speegle »
