Author Topic: Engine date code  (Read 1541 times)
Offline twister428
Engine date code
« on: February 14, 2014, 12:38:39 AM »
Does anybody know the origin of the 2 dots under an engine date code and what they mean?
Re: Engine date code
« Reply #1 on: February 14, 2014, 01:26:11 AM »
I'm guessing your referring to the casting date rather than the assembly date. Believe it didn't "mean" anything other than it was a running change/pattern incorporated at the casting plants after a particular time as we see it on third member housings also. Think it was first seen/used in 69 - may have just helped in the orientation for reading the numbers right side up but its usage does not seem consistent (have it on some 69 castings and others without)
Example have a May 69 date with the dots and a October 69 without
Third member example with dots
And a FE block
351 (Dec 1970 Without dots
Offline twister428
« Reply #2 on: February 14, 2014, 04:51:17 PM »
Thanks for the input. What you say varifies what I always thought.
« Reply #3 on: February 14, 2014, 08:33:56 PM »
Received a PM that referenced a comment from a generic Muscle car book suggesting that the dots and no dots related to different shifts. Not clear what car manufacturer they were referring to (writers included a Galaxies and a Pontiac restorer) and the text referred to singel and double dots. Never heard of single dots on a Ford cast part so maybe the reference was related to non- Ford built cars.
At this point a single unconfirmed reference - the search for complete understanding continues ;)
« Reply #4 on: February 15, 2014, 12:24:01 AM »
There is a possibility that the dots indicate a "9" as opposed to a "6". Remember, the guy putting them in the mold was looking at the mirror image.
« Reply #5 on: February 15, 2014, 07:27:27 PM »
That was a thought until you find the double dots under the 0 (for example) representing a 1970 cast part ;)
