Author Topic: Heater Resistor Fasteners  (Read 2625 times)
Offline Sunlitgold68
« on: March 01, 2010, 03:50:14 PM »
Does anybody know where you get the small round white plastic fasteners that secure the heater resistor to the heater box?
8T01C204XXX
Built May 14th, 1968
Offline Twilight65
  • Gold Level Subscriber
Re: Heater Resistor Fasteners
« Reply #1 on: March 01, 2010, 04:30:35 PM »
I believe a Panduit Push Rivet Part # NR1-C is as close as you can get. Dimensionally checks out almost identical to my 66 heater box. See attached links.
Dave
http://www.panduit.com/Support/Search/index.htm?Nu=P_RollupKey&Text=NR1-C&Filter=P_ItemCode
http://www.panduit.com/groups/MPM-LP/documents/PartDrawing/106560.pdf
« Last Edit: March 01, 2010, 05:14:16 PM by Twilight65 »
Offline gtamustang
  • CPM
« Reply #2 on: March 02, 2010, 03:44:40 PM »
Sounds like you are going to do the entire restoration yourself! I have a few of the original white fasteners.
Regards,
Pete Morgan
« Reply #3 on: March 02, 2010, 03:55:31 PM »
I've done as much as I can, the heater box turned out nice. There's still quite a bit for you to do, plus you can fix anything I messed up  ::)
8T01C204XXX
Offline mjd 65
« Reply #4 on: May 18, 2016, 11:08:31 PM »
I thought I'd revive this old thread in case anyone is looking for these unusual nylon retainer pins.  West Coast Cougar sells an accurate reproduction.
http://www2.cougarpartscatalog.com/pushretainer.html
« Last Edit: May 18, 2016, 11:13:33 PM by mjd 65 »
Mel
