Author Topic: 66 - 67 Convertible owners, need your help...  (Read 2815 times)
Offline Oz390
« on: February 06, 2014, 09:50:06 AM »
Trying to nail down some dates for a design change to the main frame hinge, over the door glass. Docs I have are not too clear.
If you have a top frame with a main hinge as shown below, and believe it to be original, if you could post or PM me your build date it would be appreciated.
Tried a few other forums, one reply... not really a good sample to document a range of dates!  ;)
8R03S : 76A I 2A 15M 72 5 U
Offline aaatp
Re: 66 - 67 Convertible owners, need your help...
« Reply #1 on: February 06, 2014, 10:33:54 AM »
Looks just like mine.  My car was built in Dearborn with a proposed build date of Feb. 18th 1966.
Offline rodster
« Reply #2 on: February 06, 2014, 04:13:17 PM »
I'll take a look at my 67 but not sure how much I can see w/ the top up?
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline Oz390
« Reply #3 on: February 07, 2014, 04:13:42 AM »
Thanks one more new range date! Pushed it one month earlier!
The face of the pin is unique, has the little hole in it shown.  Should be able to see that side (the head of the pin shown is on the inside on the few I've seen).  May be able to feel the hinge for how thick it is and if its got the pin one side bush the other if not...
Offline outlawincorporated
  • Kangaroo Herder
« Reply #4 on: February 07, 2014, 08:36:09 AM »
66 convertible june built. from Dearborn, as per image provided.  will check my other convertible in up coming days.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline Oz390
« Reply #5 on: February 07, 2014, 10:47:33 PM »
Ok, great... the guy who solf me these parts indicated they came off a '67, but nothing more than that.   Any '67 owners who can chime it to find an estiamted end date... ?
Offline Paperback Writer
« Reply #6 on: February 10, 2014, 08:00:37 PM »
Hi Oz390,
Not sure if you saw this, but I posted a reply to your earlier inquiry here:
http://www.concoursmustang.com/forum/index.php?topic=7479.msg42821#msg42821
Cheers!
1967 390 GTA Convertible
7R03S110###
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #7 on: February 11, 2014, 06:01:22 PM »
Richard,
You probably know already but, that's the exact hinge my MAR 66 Metuchen car has and the same revision I drew for you a couple of years ago.
That one appears to have a "C-bore" in the opposite half for the head of the screw.  I can't remember if mine had that or not.
66 Metuch Conv
Nightmist, Std Blu Int
Offline bryancobb
  • 2009 Ridn' Around
« Reply #8 on: February 11, 2014, 06:22:19 PM »
Here's the pins right before I sent them to the platers.
#1's or #7's...can't remember which...And the 4 black bushing halves in the background.\
66 Metuch Conv
