Author Topic: Early Dearborn Hood Hinge Color  (Read 1662 times)
Offline lscman
« on: February 06, 2014, 09:38:44 AM »
Someone give me their take on correct early 65 Dearborn hood hinge color as I've seen them painted black and some say natural color and some say Phosphate and oil?
Offline kutzoh
  • Gold Level Subscriber
Re: Early Dearborn Hood Hinge Color
« Reply #1 on: February 06, 2014, 10:02:12 AM »
What do you mean by "early '65"? Probably would be helpful if you put your build date in your profile since so many change-overs are date specific. The early, deemed '64.5 models, hood hinges were painted black. The 1965 models were phosphate & oil. I don't know if the change-over was made in August, 1964 with the model year change or not.
Greg
« Reply #2 on: February 06, 2014, 12:33:31 PM »
Have seen black hood hinges on cars built into Sept/Oct of '64.  Another one of those transition items... not really a "64.5" only feature.
Offline lscman
« Reply #3 on: February 06, 2014, 01:30:12 PM »
Car was built in July/Aug. 1964?
« Reply #4 on: February 06, 2014, 07:00:13 PM »
Definitely should have black hood hinges then.
Offline big_mike
« Reply #5 on: February 06, 2014, 11:11:01 PM »
Black hood hinges here (of course being a July 28th '64 build date).
Not trying to hijack the thread but it is somewhat related - are the trunk hinges also supposed to be black or body color?  Mine are painted black (but was repainted over 20 years ago and the PO could've done that).
« Last Edit: February 06, 2014, 11:15:41 PM by big_mike »
1964.5 289 4V Auto Coupe
5F07D
Color S = Cascade Green
Trim 46 = White with Black Appts
Date 28G = July 28th
DSO 43 = Rockford
Axle 1 = 3.00
Trans 6 = C4 Auto
« Reply #6 on: February 07, 2014, 01:02:09 AM »
Trunk hinges should be body color.  Be sure to start a new thread that are different than the topic... makes it easier for folks to see and get answers.  Also helps when searching old posts.
Offline big_mike
« Reply #7 on: February 07, 2014, 01:13:00 AM »
Thanks caspian65 - will do that next time.  :)
5F07D
DSO 43 = Rockford
Axle 1 = 3.00
Trans 6 = C4 Auto
