Author Topic: 65 Door Striker Color  (Read 2342 times)
Offline lscman
« on: February 05, 2014, 07:12:44 AM »
What color or process are the door strikers on early 65 Mustang?
« Last Edit: February 06, 2014, 09:34:54 AM by lscman »
Offline Richard P.
Re: 65 Door Latch Color
« Reply #1 on: February 05, 2014, 07:17:44 PM »
It is my understanding that they should be Zinc Dichromate.
« Reply #2 on: February 05, 2014, 07:39:55 PM »
I've found variations on door latches (the piece on the door).  Most I have seen have a galvanized base, with zinc with dichromate (gold) color outer part and latch clasps.  Some I have seen have more of a silver outer part and then gold color latch clasps.
If you decide to have the original latches plated, be sure to remove the coil springs as the zinc plating process will cause the springs to be more brittle and prone to breakage.
Offline lscman
« Reply #3 on: February 06, 2014, 09:19:28 AM »
I know about the door latch in the door but I'm asking about the striker on the back of door opening with the stud that sticks out?What color is it as I've seen yellow zinc and cadium silver color and my car is early Dearborn car?
Offline Richard P.
Re: 65 Door Striker Color
« Reply #4 on: February 06, 2014, 10:17:38 AM »
As I stated earlier,the color that I've seen is Zinc Dichromate for the striker.
« Reply #5 on: February 06, 2014, 12:35:22 PM »
Agree with Rich... your original post was labeled as 'latch' color, which I took to mean the part in the door.
Offline lscman
« Reply #6 on: February 06, 2014, 03:29:13 PM »
What does that color zinc dichromate look like?
« Last Edit: February 07, 2014, 07:47:10 AM by lscman »
« Reply #7 on: February 06, 2014, 04:35:31 PM »
What does that color zinc dichromate look likelike?
Dichromate is a dye placed over a zinc plated base. Since its a dye it often does not hold up well to exposure and pieces often take on a zinc or sliver look over time.
Zinc dichromate has a goldish tint some times (on larger pieces - like large master cylinder caps) with a multi-hue with green and red shading. Finish often is determined or at least effected by the underlying metal and the process (how much dye and how bright of a zinc finish was applied) Also the finish will loss some of its "shine" over time with exposure to the air and things like cleaners
The alternator fan, pulley and nut in this picture are plated - Zinc dichromate
Fresh Zinc on right - Zinc dichromate on left
