Author Topic: Replacement of entire floor pan  (Read 8260 times)
Offline Ryan Miller
Re: Replacement of entire floor pan
« Reply #15 on: February 13, 2014, 02:22:51 PM »
Date codes and panel numbers are easily reproduced... ;) :)
« Reply #16 on: February 13, 2014, 04:36:54 PM »
I was at a local VW shop yesterday where there was a 64 Karman Ghia having it's rusted out floor pans replaced. Same technique for removal of the old pans (drill out old welds), same problems in replacement metal (single good source and expensive), same procedure for welding in the new pan (wire weld small holes and grind), same situation for putting the seat base back in (the same welding technique) everything was the same, and it looked good.
« Reply #17 on: February 14, 2014, 12:58:04 AM »
Like to see that  :o
« Reply #18 on: February 14, 2014, 02:53:19 PM »
Like to see that  :o
Cut dates out of old sheet metal and weld in.  The body guy I use has a little collection of date codes, lol.
« Reply #19 on: February 14, 2014, 08:26:02 PM »
Seen that a few times ;)   From the comment thought the suggestion Ryan Miller was making that he was reproducing the stampings rather than transferring
