Author Topic: Odd tag on upper cowl  (Read 4891 times)
Offline C5ZZ
« on: January 30, 2014, 06:24:22 PM »
Has anyone ever seen a tag like this? It is on a 66 NJ coupe 6T07C177122
Any idea what it is for?
MCA # 00945
Rangoon Red/Red Interior
Offline tomtri66
  • Bronze Level Subscriber
Re: Odd tag on upper cowl
« Reply #1 on: January 30, 2014, 07:29:30 PM »
Yes.  I have this tag on my NJ coupe as well 6T07T194XXX.  I believe the consensus is that it was some sort of inspection tag for the cowl assembly weld if I'm not mistaken.  There is a thread somewhere on this board discussing it.
on a side note, our cars were built pretty close together it seems. :)
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Offline tomtri66
« Reply #2 on: January 30, 2014, 07:34:12 PM »
Found this post from Pete Bush:
 Pete Bush
Hero Member
Re: My New Project
« Reply #16 on: September 06, 2012, 09:18:54 PM »
Quote
Fria recounts a conversation he had with Bob Negstad:
" Bob Negstad related to me that they had problems with inadequately trained workers not producing secure spot welds. Supervisors examined the moving chassis and, using a screwdriver, tried to break loose a weld that looked suspect. If the weld failed, then the area was rewelded with what was called a security weld to better secure the joint. Workers didn't like to see their welds fail, said Negstad, because the worker knew he wasn't doing his job properly and the supervisor was taking notes."
The tabs might have identified the inspector that was looking at these welds. Or it might have identified the workers that actually did the welding. If a weld failed on the S6 side of the chassis, they could go right back to that worker and let him know - short and sweet.
Report to moderator     Logged
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #3 on: January 30, 2014, 08:07:32 PM »
Have seen them many times. Haven't found anyone that explained their purpose or usage.
« Reply #4 on: January 30, 2014, 08:59:42 PM »
The punch designs are similar to punch-outs on buck tags... could be a correlation between them.
Offline Ivygreen65
« Reply #5 on: January 30, 2014, 09:05:11 PM »
Steve,
I've got the same tags on my March 65 Dearborn convertible.  However, the right one is stamped P4 and the left one is stamped S6.  Apparently they have a purpose, but Dearborn used numbers and letters while Metuchen used symbols.  I've racked my brain, knowing the options and equipment that my car was originally outfitted with, to find a meaning for them, but I haven't had any luck yet translating what their meaning might be.
Offline outlawincorporated
  • Kangaroo Herder
« Reply #6 on: January 30, 2014, 09:38:19 PM »
3 of my 66 NJ (January, March, April) cars have evidence of this metal tag as well. they are all different lengths, two have no punch-outs and the other one does. most restorations removed any sign of this tag, in due course all mine will be photo-graphed and returned when the restorations are done, till then its another little item we will learn more about over the years. good topic.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline C5ZZ
« Reply #7 on: January 30, 2014, 10:47:31 PM »
The car is not mine its in a salvage yard I go to,
has a lot of rust, has seen better days!
MCA # 00945
Offline C5ZZ
« Reply #8 on: January 30, 2014, 10:52:20 PM »
Thanks for all the replys, interesting info, will have
to look for the tags on the cars at the 50th show.
MCA # 00945
« Reply #9 on: January 31, 2014, 01:23:48 AM »
It's not uncommon to see these tags ripped off on original cars too.  If you know where to look, can usually see remnants or the 'edge' of the tag.
Offline tomtri66
« Reply #10 on: February 06, 2014, 12:24:01 AM »
Best pic I can find of this tag on my car before it was, sadly, removed when cowl repairs were done during a restoration in  the '90s.....
C/O    762
4        A20     6T07T194XXX
65A       Y        22
Offline rodster
« Reply #11 on: February 06, 2014, 04:10:52 PM »
Look at the 67's too as some had the cowl tag.   ;)
http://www.concoursmustang.com/forum/index.php?topic=3083.msg16411#msg16411
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline 6T07K
« Reply #12 on: September 18, 2016, 11:55:58 PM »
I ran across this old topic and thought I'd revive it with some addl. info. Pics are of similar cowl tabs I found on a May 65 Dearborn FB I'm working on.I'd never seen these before and queried Mr. Turner,Mr. Barkley and Mr. Porter to try to solve the mystery. They had seen them before and led me to the old posting here.I can't really make out the shape of the punchouts but they do remind me of the punches on buck tags. My apologies on the pics. I wasn't sure how to post them but gave it a try anyway.
Offline rodster
« Reply #13 on: September 19, 2016, 01:10:57 PM »
You done good on the pics!  ;)  Welcome and thanks for sharing. Sounds like an interesting project car.
1984 SVO - 2A
Offline 6T07K
« Reply #14 on: September 19, 2016, 05:19:31 PM »
Here's a couple more for reference.
