Author Topic: 67 zerk fittings  (Read 1325 times)
67 zerk fittings
« on: January 26, 2014, 08:40:36 AM »
Trying to confirm that I have the factory correct grease (Zerk) fitting setup:
A. No fitting, no plug, not even a hole
* Tie Rods, inner (3A131)
* Tie Rods, outer (3A132)
* Idler arm (3355)
* Universal joints (4635)
* Power steering cylinder assembly (3A540)
B. Threaded hole with 1/4"-28 tapered hex head plug (374714)
* Ball joints, upper (3049)
* Ball joints, lower (3050)
* Power steering control valve actuator (3783) [added after replies to original post]
* Shaft Bushings, Upper Control Arm (3069) [moved from category "A" after replies to original post]
C. Grease fitting 1/4"-28 (87907 - straight; 87924 - 90 degree elbow) installed in the factory
* Nothing ?
« Last Edit: January 28, 2014, 04:50:11 PM by 67gta289 »
Re: 67 zerk fittings
« Reply #1 on: January 26, 2014, 10:49:06 AM »
John there is a threaded hole with plug on the control valve. The other you have looks right to me.
« Reply #2 on: January 26, 2014, 03:09:21 PM »
+1 Not sure if I would refer to that section as the control valve but  you get the idea ;)
« Reply #3 on: January 26, 2014, 04:15:56 PM »
Looks like the power steering control valve "actuator", part 3783, assembly serviced in the 3A730 kit, does have the hex plug 374714.
Thanks for completing the picture.
Offline TLea
« Reply #4 on: January 28, 2014, 08:31:15 AM »
Upper control arm shafts have a plug but no zerk
« Reply #5 on: January 28, 2014, 01:26:54 PM »
+1
Good catch - skipped over that detail :(
The first uppers used on 65's were the style with no hole for the zerts. All that followed did as Tim mentioned
« Reply #6 on: January 28, 2014, 05:17:51 PM »
Thanks.  I corrected my original post to reflect this.
