Author Topic: 65/66 disc brake steel wheel  (Read 5163 times)
Re: 65/66 disc brake steel wheel
« Reply #15 on: February 14, 2014, 05:39:36 PM »
     This is a picture of the OE 65 Disc Brake wheel from my May/65 GT.  I think the contours between the lips are what should be compared to a known Drum Brake car ?  The brake assembly would be on the right.  Brian
« Last Edit: February 15, 2014, 12:32:31 PM by Brian Conway »
Offline C5ZZ
« Reply #16 on: February 15, 2014, 12:04:02 PM »
Can you post a picture of the front and back of your wheel as well?
I have a drum brake wheel that I can take pictures of also.
MCA # 00945
Rangoon Red/Red Interior
« Reply #17 on: February 15, 2014, 07:05:02 PM »
Although not related directly to this subject the evolution of the brake calipers was all cast iron on steel wheel cars and deluxe wheel cars got a caliper that was painted silver or plated silver on the outside facing half. It evolved to all of the calipers being cast on the back half and silver on the front half for simplicity. I only mention this because I wonder if there were two separate steel wheels one of disc and one for drum. Ford maybe decided to make the wheel universal for simplicity sake. If i were to guess I would guess it would be around the same time in 65 that the calipers appeared to change. That is if there is some type of correlation . Just a thought .
Offline rodster
« Reply #18 on: February 15, 2014, 07:19:02 PM »
Very interesting indeed....
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #19 on: February 15, 2014, 07:37:35 PM »
Maybe someone can compare dimensions to a '65 styled steel wheel?  I've never had a problem with those fitting disc brake cars.
Offline C5ZZ
« Reply #20 on: February 16, 2014, 12:08:50 PM »
Here are a few pictures of a original wheel off a 65 SJ conv.
Measures 14x5 and the car had drum brakes.
MCA # 00945
« Reply #21 on: February 16, 2014, 12:51:30 PM »
     They look like the same wheel.  My example is date stamped 5MD, also stamped with AC, has the small hole and came with dual red line tires.  Brian
« Last Edit: February 16, 2014, 01:54:52 PM by Brian Conway »
Offline C5ZZ
« Reply #22 on: February 16, 2014, 02:34:13 PM »
They do look the same, mine has a HM4 stamp, usually they are stamped
with the year first like 4MH, have seen wheels stamped both ways.
« Last Edit: February 16, 2014, 02:39:51 PM by C5ZZ »
MCA # 00945
