Join us on Facebook: Search for 'ConcoursMustang' Private group!https://www.facebook.com/groups/concoursmustang/Indiana SAAC Fall Classic , French Lick, IN Oct 11-12http://www.insaac.org/SAAC National-Sanctioned Concours Event
Yes, that is true. When I had my 65 GT Coupe back in 1968, I had a flat tire up front. I put the spare on, but the car wouldn't move. Turns out someone replaced the spare with a standard drum wheel. I have no pictures for you; just an anecdote.
Do you know if the spare you tryed to put on was a 65/66 wheel?I have never seen one of these special wheels, just heard discussionswhere some say there is a special wheel and some say there is not one.
Jan '65 MPC:8cyl C1AZ-1007-A 15" x 5.50" - use with 15" x 7.10" tires6 cyl C0DD-1007-K 13" x 4.50" - use with 13" x 6.50" tires - 4 bolt holes - 4 1/2" bolt circle8 cyl C4GY-1007-B 14" x 5.0" - 5 bolt holes - 4 1/2" bolt circle8 cyl C2OZ-1007-B 13" x 4.50" - 5 bolt holes - 4 1/2" bolt circleSS wheel: C5ZZ-1007-A For 2 1/4" hub cap - 14" x 5.0" - 5 bolt holes - 4 1/2" bolt circle6 cyl C4GY-1007-A 14"x4.50" - 4 bolt holes - 4 1/2" bolt circleJan '66 MPC:C1AZ-1007-AC4GY-1007-BSS wheel: C5ZZ-1007-B Chrome - for 2 1/4" hub cap - 14" x 5.00" - 4 1/2" bolt circle6cyl C0DZ (13")6cyl C4DZ (14")No mention anywhere in wheel section about disc brakes.
Having been bit too many times in the past by relying on Ford documentation, I would have to hesitate to say the issue is settled, but at least it appears from the documentation that there was no disc brake wheel for 65-66.
Should be reasonably easy to test this out... someone with known wheels from a drum brake car can try to fit them on a factory disc brake car.
