Author Topic: 68 C4 transmission finishes  (Read 2447 times)
Offline Stangly
  • Gold Level Subscriber
« on: January 18, 2014, 02:05:59 PM »
Hey guys have my tranny apart and would like to confirm the finishes of a few items.  Any input, tips or advice would be greatly appreciated.
1.  Low reverse servo cover has a few ruminants of what appears to be aluminum paint over phosphate.
2.  Breather tube and bracket that attaches to top bolt of LRS cover
3.  Manual shift linkage and kick down lever looks like phosphate & oil
4.  Oil pan cover no finish left to compare bare steel?
5.  Bolts that attach both servo covers & oil pan.
« Last Edit: January 18, 2014, 02:08:47 PM by Stangly »
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: 68 C4 transmission finishes
« Reply #1 on: January 18, 2014, 08:37:12 PM »
Aluminum paint is likely from an earlier rebuild - often they just rattle can everything after they are done :(
The reverse servo cover (drivers side one)  should be stamped steel  - unpainted. Think it was just bare oiled steel no plating
Tube looks to be bare steel or maybe ?  zinc plated - can still make out the lines in the surface material
Clamp appears to be darker  so guessing bare steel (no sign of plating on the ones I'm looking at)
The shift rod is either heat treated steel or Phosphate - basically the same darkness
Kick and sifter arms  appears to be
Just bare steel - possibly oiled originally to reduce the chance of rusting prior to sale
Looks to be dark finished so phosphate or dark heat treated - both about the sane tone when finished and oiled
Same finish for the band adjusting nuts and rods
Offline Stangly
« Reply #2 on: January 19, 2014, 01:49:22 AM »
Thanks a bunch Jeff this will get me going in the right direction.
68 Coupe J-Code
2001 V6 Laser Red
Offline TLea
« Reply #3 on: January 20, 2014, 10:00:56 AM »
The reverse servo cover (drivers side one)  should be stamped steel  - unpainted. Think it was just bare oiled steel no plating  +1
Tube looks to be bare steel or maybe ?  zinc plated - can still make out the lines in the surface material  Bare steel
Clamp appears to be darker  so guessing bare steel (no sign of plating on the ones I'm looking at)  +1
The shift rod is either heat treated steel or Phosphate - basically the same darkness  heat treated
Just bare steel - possibly oiled originally to reduce the chance of rusting prior to sale  +1
Same finish for the band adjusting nuts and rods +1
« Last Edit: January 20, 2014, 10:03:43 AM by TLea »
Offline Stangly
« Reply #4 on: January 23, 2014, 09:28:30 PM »
Thanks guys for the info, going to try out RPM on the bare metal items, have either of you guys used this product.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #5 on: January 23, 2014, 10:28:06 PM »
Seen it never used it
Online ruppstang
« Reply #6 on: January 26, 2014, 04:16:50 PM »
Here is my finished C4.  I sprayed with Boshield when it was finished to protect it.
