Author Topic: Sway Bar Finish  (Read 2668 times)
Offline kutzoh
  • Gold Level Subscriber
Sway Bar Finish
« on: February 26, 2010, 05:51:59 PM »
Just a quick question....what was the finish on the front sway bar, painted black or natural?
Greg
Re: Sway Bar Finish
« Reply #1 on: February 26, 2010, 05:57:59 PM »
the bar itself would be semi-gloss black.
Offline kutzoh
Re: Sway Bar Finish
« Reply #2 on: February 26, 2010, 06:05:00 PM »
Wow- thanks for that fast replay!
Greg
Re: Sway Bar Finish
« Reply #3 on: February 28, 2010, 02:25:07 AM »
Sometimes the dark heat treat finish on front sway bars and coil springs are mistaken for paint. I have seen both unpainted (dark gray/black heat treated)and what appears to be painted on 65 on and 66 SJ GT350's. Bob
Offline Crgjohnson
Re: Sway Bar Finish
« Reply #4 on: June 11, 2020, 11:26:40 AM »
I just ran into a heat treated front sway bar on a 28k original miles 1969 3/69 Dearborn M code built Cougar. I had heard they were out there but had never ran across one. The bar also had what looks to be a daub of gold (most likely yellow) It also had a violet paint daub on one end which I have never seen before.
Craig
« Last Edit: June 12, 2020, 12:03:15 AM by Crgjohnson »
70 BOSS 302(Dearborn 10/69) Medium Blue Metallic, CA emissions
70 BOSS 302(Dearborn 10/69) Calypso Coral, CA emissions
09 Shelby GT 500, factory stripe delete
MCA 69-71 concours BOSS gold card judge
Mustang restorer (hobby)
69 Cougar 3/69
Re: Sway Bar Finish
« Reply #5 on: June 11, 2020, 11:28:51 PM »
That’s pretty unbelievable. How many 1969 Cougars were built in 1970? The real answer is none.
I just ran into a heat treated front sway bar on a 28k original miles 1969 3/70 Dearborn M code built Cougar. I had heard they were out there but had never ran across one. The bar also had what looks to be a daub of gold (most likely yellow) It also had a violet paint daub on one end which I have never seen before.
Craig
Offline Crgjohnson
Re: Sway Bar Finish
« Reply #6 on: June 12, 2020, 12:04:41 AM »
You are correct it was a typo and has been corrected. Thanks for the snarky reply though
69 Cougar 3/69
Re: Sway Bar Finish
« Reply #7 on: June 12, 2020, 10:28:38 AM »
Not meant to be snarky - meant to state the obvious.
