Author Topic: '65 V8 intake temp sender reducer  (Read 1712 times)
« on: January 15, 2014, 03:18:56 PM »
Does anyone know a source for the intake temp sensor reducer on a '65 V8?  The bigger temp senders weren't used until later in the year.  I have an April '65 A code I'm working on and the intake had the reducer removed.
Re: '65 V8 intake temp sender reducer
« Reply #2 on: January 15, 2014, 06:49:47 PM »
The originals wouldn't have the hex top.  It's a pipe fitting thread.  Thanks for checking though.
Offline MattDoscher
« Reply #3 on: January 15, 2014, 06:57:26 PM »
I don't mean to get off topic but would having/not having this reducer affect temp gauge readings?  Or would this be one of the negative effects of repro gauges?
Matt Doscher
5H25T582252
Offline mts
« Reply #4 on: January 15, 2014, 06:59:46 PM »
Charles - The part is a "face bushing" 1/8 female pipe to 3/8 male pipe.  It's an odd size.  Believe it or not you can get one through Amazon.com.  http://www.amazon.com/Lead-Free-Fitting-Bushing-Female/dp/B003TWP2KO
« Reply #5 on: January 15, 2014, 08:38:55 PM »
Thanks for the info, found some steel ones like original online.  Min order of $15, so had to buy about 25 of them, lol.  Hope they fit!
Offline rodster
« Reply #6 on: January 16, 2014, 11:11:21 PM »
April '65 A code.... same as mine.  ;)
Is this the part you are talking about and does it look correct?  Looks like brass?
Rod
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #7 on: January 17, 2014, 12:25:45 AM »
Yes, that's it.  You're right about it being brass, had a mental image of them being steel.
