Author Topic: Correct 1966 Spark Plugs?  (Read 7844 times)
Re: Correct 1966 Spark Plugs?
« Reply #15 on: June 14, 2014, 12:30:05 PM »
Great thing about ebay they have a message feature and you can ask for more info and pictures  ;)
Yes it is - other great thing is to have someone else confirm it for you :)
Offline C5ZZ
« Reply #16 on: June 14, 2014, 07:09:49 PM »
There are typically a few sparkplugs with Part # B8A-12405-A sets for sale at any given time.  These seem to be the most commonly available variant of the BF42s.
Both part numbers were used at the Ford dealers, B8A-12405-A is the Ford part number
while BF42 was printed on the plug its the Autolite number (now Motorcraft) and can be used as well.
B8A-12405-A is not a variant of the BF42, its the same thing, you can find it printed on the box.
MCA # 00945
Rangoon Red/Red Interior
Offline AU SNK
« Reply #17 on: June 15, 2014, 09:45:48 AM »
True True, I figured anyone on the board that was in need would do research on the plugs before pulling the trigger. Hope it helps someone out.
Unrestored 66 Metuchen, NJ Fastback 6T09C2435XX
Sauterne Gold Metallic, Lt. Ivy Gold Crinkle Vinyl and White Crinkle Vinyl, Pony Interior
Offline evantugby
« Reply #18 on: January 17, 2018, 08:00:16 PM »
Gents,
I'm looking for the correct spark plugs for a 1966 K-code build date of 23 Oct 1965 out of Metuchen.  Am I correct that they should be a BF-32?  The salesman at Green Sales Company in Cincinnati Ohio said so but haven't been able to verify.
« Reply #19 on: January 17, 2018, 08:09:50 PM »
Gents,
Yes the correct heat range is BF32 .This info can be confirmed in the specification supplement to the 66 shop manual among others. The assemblyline plug would have a star on the insulator that the later versions do not have .
Offline evantugby
« Reply #20 on: January 17, 2018, 10:28:05 PM »
Much appreciated Bob and J.
Offline Morsel
« Reply #21 on: March 01, 2018, 08:29:52 PM »
Wondering about this, so was the BF-32's for K-Codes and the BF-42's for standard V8's? I was just researching and searching the forum and came across another thread that all they talked about was the BF-42's, no mention of these BF-32's???
It's just I have a line on some original BF-42's, but I have a 66 K-Code and want to get the correct ones... also, anything I need to "watch out for" with original NOS spark plugs, they do have the original stars on the plug?
Thanks...
« Reply #22 on: March 01, 2018, 08:33:42 PM »
Not really sure of which "other thread" your referring to. It may have been solely focused on the standard small block application or the OP never identified their specific need or application  ::)
Yes they would have originally had stars. Haven't found enough documentation to figure out the change over that related to the number of ribs. Those will be pretty much covered by the boots so its not going to likely be a discussion once installed.
« Reply #23 on: March 02, 2018, 05:10:00 PM »
With the current low octane gas, use a BF-42 on a 289HP for every type of driving, and put the BF-32 in for shows.
« Reply #24 on: March 02, 2018, 08:57:02 PM »
Offline Hipo giddyup
« Reply #25 on: July 23, 2018, 01:40:35 PM »
 I just purchased a box of NOS BF42 Powertip plugs. I know have an NOS set of each, one set with the Autolite Star logo, the other with the Powertip. Which would be correct for a July 1966 built, Dearborn 289 2V coupe?? Also, does anyone know when the Star logo type plug went away, and the Powertip came into being? Thx
« Reply #26 on: July 23, 2018, 02:31:44 PM »
Power tips came out later, so you need the star logo ones.
« Reply #27 on: July 23, 2018, 11:17:01 PM »
I was thinking so, I seem to remember that Power tips were a 68’ and up transition??  thanks Charles.
« Reply #28 on: July 25, 2018, 02:56:50 PM »
 Here are a few pics. I picked these up at $2 per plug. Feel pretty good about that.  ;)
« Reply #29 on: July 25, 2018, 02:57:14 PM »
one more
