Author Topic: What is the PN for the standard 1968 Outside Mirror?  (Read 1173 times)
Offline johnkn
« on: January 12, 2014, 11:34:51 AM »
Greetings,  what is the correct original part number for the standard (not remote) left side mirror for a 68 Mustang?   Was there then a later service replacement?   Were they shared with any other cars?     Thank you....
Online 67gta289
Re: What is the PN for the standard 1968 Outside Mirror?
« Reply #1 on: January 12, 2014, 12:28:31 PM »
This is probably more aligned with the later service replacement since it is from the 1975 master parts catalog.  I'm sure someone else will offer to compare with an earlier version and advise us if there is a more correct number.
The number 17682 applies to the "mirror assy - rear view outside - includes gasket" part.
For the 68 Mustang, it looks like from page 2665:
1. The original left hand manual mirror retangular head was part C8AZ-17692-B.
2. The original was replaced by D4AZ-17696-A which says it works for both right hand and left hand applications.
With the original at revision B, earlier MPC's might clue us in to whether or not the factory installation was an earlier rev. "A".
Switching to use on other cars, the first clue is that the third character is an "A".  Something designed specifically for the Mustang would have a "Z" (but of course a "Z" part could be used on a Cougar as well, or later on for a Maverick/Comet)
Doing a text search has a few results, as can be expected.C8AZ-17692-B is assigned for:
1. 68 full size Ford (A)
2. 68 Mustang (F)
3. 72 T-bird (S)
4. 67 Bronco (U)
« Last Edit: January 12, 2014, 12:33:25 PM by 67gta289 »
« Reply #2 on: January 12, 2014, 01:46:19 PM »
Per the 1968 Mustang Body Assembly Manual, the part number designed to be used is C8AB-17683-B, ref AM0021 pg 37. That is a full size Ford part number and there is no guarantee that that is what was used, I believe that mirrors were packaged and dealer installed along with the radio antenna. The gasket had a 67 Mustang part number, C7ZB-17C701.
I strongly suggest that you get a set of 1968 Assembly manuals which does provide a lot of answers and indicates Ford engineering's concept of how the cars were to be assembled.
Offline johnkn
« Reply #3 on: January 12, 2014, 01:59:30 PM »
Thank you both!
