Author Topic: help needed on axle ID  (Read 1310 times)
Offline silverfox
« on: January 08, 2014, 05:49:15 PM »
Hi all,
Can you please help me with decoding my axle in my 65 K code.
I have been on Mustang Tek to decode the tag (see pic as attached) and it seems to say from the site that a HCZ-H decodes as a 3.89, whereby the ID on the bottom LHS of the tag, shows it to be a 3.50 ?
I'm now very confused, can anyone help ?
many thanks
http://www.mustangtek.com/differential/Differential.htm
WCZ-H, Unconfirmed Application. Information may or may not be complete or accurate65 Mustang, 9 inch, 3.89, 28, Non lock 2 M M
http://www.mustangtek.com/FordDateDecoding.html
Current Mustangs:
1965 Fastback 289 K Code - Hi-Po - Caspian Blue
1970 Mach 1 Sportsroof 351C Auto - White - Project car and in Resto (started Sept 2012)
Past Mustangs:
1966 Fastback GT350 clone, Hi-Po 289, 4 Spd Man, White/Blue
priceless
  • Guest
Re: help needed on axle ID
« Reply #1 on: January 10, 2014, 11:19:21 AM »
Here is a  couple photos from the Kevin Marti "Mustang and Cougar tag book". The photos are in order for 65.
NOTE: the first photo states before Sept. 64.
the second photo states after Aug. 64.
Hope this helps.
« Last Edit: January 10, 2014, 11:25:52 AM by priceless »
Offline silverfox
« Reply #2 on: January 10, 2014, 06:09:45 PM »
Hope this helps.
thank you, very much appreciated.
the info does seem to indicate that the CZ-H tag can either indicate a 3.50 or 3.89 and my tag showing a 3.50 does fit with the Kar in the HiPo registry.
Cheers, Chris
Current Mustangs:
Past Mustangs:
