Author Topic: '68 seat belt warning light  (Read 4454 times)
Offline Oz390
« on: January 04, 2014, 09:07:43 AM »
Bought a Fog harness/switch and "Z plate" (as I call it, plate that mounts under the fuse box and breakers mount to in '68s) and as a bonus it looks like the seat belt lamp option is included.
It appears this is just a capacitor (about 1 1/2" long) mounted to the plate with a hot feed and then the wire to the back of the inst cluster.  Lights up for a few seconds then goes out when tested on a battery.
Is this the entire option?  Hot feed wire from main harness to capacitor, capacitor on Z plate, feed to lamp and socket in cluster?  Just comes on when you hit the ignition for a few seconds and then goes out?
8R03S : 76A I 2A 15M 72 5 U
Re: '68 seat belt warning light
« Reply #1 on: January 04, 2014, 09:46:36 AM »
Yes that is it for a 68.
« Reply #2 on: January 04, 2014, 05:32:23 PM »
..........Is this the entire option?  Hot feed wire from main harness to capacitor, capacitor on Z plate, feed to lamp and socket in cluster?  Just comes on when you hit the ignition for a few seconds and then goes out?
Pretty much it for these basic systems - all works as a timer.
Offline dave6768
« Reply #3 on: January 04, 2014, 06:00:45 PM »
Did all 68's have the seat belt reminder light?  Mine does not have it...not sure if it ever did.  My 67 does have one.
« Reply #4 on: January 04, 2014, 06:15:26 PM »
The seat belt warning system was part of the courtesy group option, I don't think it was a separate option. The relay is thermally activated which turns off after a few seconds, but the bi-metallic strip still has 12V going thru it while the car is running. The major problem after 40-45 years is the contacts gets pitted and the lamp doesn't light up, and the contacts may even fuse together, lamp won't go out. There is a difference between the 65-66 and the 67 on types only in mounting. Expect to pay $25 plus. Service part number for reference is  - D1AZ-10B924-A and the housing is marked C7AB-10B924-A or B, or D2AB-10B924-AA. The 65-66 service number is C6AZ-10B924-A.
« Reply #5 on: January 04, 2014, 07:29:07 PM »
I think they were part of the deluxe seat belt option.  Also included with the convenience control panel option.  If both options were ordered, the convenience control panel type ruled.
« Reply #6 on: January 04, 2014, 08:40:03 PM »
+1 Marty
Offline Oz390
« Reply #7 on: January 05, 2014, 06:19:15 AM »
A few pics of the items.  Did not recall the separate ground wire, not sure if its part for the seat belt setup, but appears so as I have never seen it on a fog light equipped car.
« Reply #8 on: January 05, 2014, 10:14:05 AM »
The ground wire went to the wiper motor bracket, there should be a predrilled hole. The ground was not necessary for the circuit breakers but was needed for the seat belt relay.
« Last Edit: January 06, 2014, 12:26:30 AM by ruppstang »
Offline dave6768
« Reply #9 on: January 05, 2014, 09:18:33 PM »
+1 Marty
Yes, my 67 does have deluxe seat belts.
