Author Topic: Engine Block  (Read 3266 times)
Offline Stangly
  • Gold Level Subscriber
Engine Block
« on: January 01, 2014, 07:06:41 PM »
I removed the bad engine block from my J-Code this last weekend.  Cylinders 3 & 7 are where the major carnage took place.  The bottom of the cylinders are broken and will need to be re-sleeved.  The rod on #3 went and broke a chunk off the edge of the mating surface where the oil pan attaches.  I came into a good deal on a new block for a replacement with the correct date codes.  My question and it may be a stupid one but here goes.  Is this block worth fixing to anybody or should I just send it off to the scrap metal yard for a few bucks.  Here is the info on the block C8OE-6015-A  7J6.  I hate to scrap this if it of value to anybody.
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Offline Rsanter
Re: Engine Block
« Reply #1 on: January 01, 2014, 10:30:27 PM »
Does it have your cars numbers stamped into it?
If it does I would wrap it up and keep it just because.
Other than that is has no real value
There are places that can repair blocks that are amazingly bad and they come out great.
But...it is expensive
Bob
Bob
68 mustang conv basket case
69 mustang conv 302 AT
Offline Stangly
Re: Engine Block
« Reply #2 on: January 01, 2014, 11:36:15 PM »
Bob,
It is not the original engine, I've heard they can be repaired but it is in most cases not cost effective.
Thanks!
68 Coupe J-Code
2001 V6 Laser Red
Re: Engine Block
« Reply #3 on: January 02, 2014, 12:49:22 AM »
if its not original then get another IMHO
Online CharlesTurner
Re: Engine Block
« Reply #4 on: January 02, 2014, 01:17:50 AM »
Post it on your local craigslist for $100 or so as a core.
Offline Rsanter
Re: Engine Block
« Reply #5 on: January 02, 2014, 01:18:04 AM »
Easy...not the original block and it's broken......
You have 2 options
One.  Junk it
Two, make it into a coffee table for a man room
Bob
Bob
Re: Engine Block
« Reply #6 on: January 02, 2014, 04:04:26 PM »
You have 2 options
One.  Junk it
Number three - add an appropriate length of chain and a buoy and you have a boat anchor. We did that with a 352 block on a lake in Massachusetts. The buoy has been replaced, it was there for 50 years.
Offline Stangly
Re: Engine Block
« Reply #7 on: January 02, 2014, 09:20:23 PM »
I like the boat anchor idea, unfortunately the way things are looking here in ND it may be July before the lakes thaw out.  It is currently 2 degrees here, tomorrow it's suppose to warm up to 40 and then by Saturday they are calling for -25 with -65 wind chills.  Jeff I was hoping you might chime in; I found a tag on the side of the block "Rettig Brothers Engine & Balancing Modesto"  Thought you may have heard of this company.  Thanks again guys for the help, everybody have a happy new year.
68 Coupe J-Code
2001 V6 Laser Red
Re: Engine Block
« Reply #8 on: January 02, 2014, 11:33:57 PM »
............... Jeff I was hoping you might chime in; I found a tag on the side of the block "Rettig Brothers Engine & Balancing Modesto"  Thought you may have heard of this company.  .............
Yes a big volume rebuilder in the area  - everything gets bored to 30 or more over. Everything gets ground to 20 at least :(
Offline sportyworty
Re: Engine Block
« Reply #9 on: January 03, 2014, 02:07:13 AM »
It's worth zero likely. Finding a C80E 6015 A dated 8J-8L is no easy task trust me. Before or after say mid Dec is a snap. That strike really limited the batch dates for the initial post strike cars of which many received 7H dates
