Author Topic: 69 351W ignition coil wire  (Read 1398 times)
Offline Buiaka
« on: December 29, 2013, 03:04:16 PM »
Hi all,
im searching the correct wires for my ignition coil. I think the red one is the distributor primary and the other? Is it the engine gauge feed wire? What correct color they should be?
The first picture is from a post here. The second is from my engine bay with pertonix installed. Just want to change to the correct plugs on the ignition coil.
Thank you
greets
« Last Edit: December 29, 2013, 03:16:15 PM by Buiaka »
Re: 69 351W ignition coil wire
« Reply #1 on: December 29, 2013, 10:50:22 PM »
For your year and engine size I believe the contact boot from the engine loom was black and the lead from the dist a light blue (robins egg blue)
« Last Edit: December 29, 2013, 10:54:40 PM by J_Speegle »
Offline Buiaka
« Reply #2 on: December 30, 2013, 02:32:44 AM »
For your year and engine size I believe the contact boot from the engine loom was black.....
Is this the ignition wire from the ignition switch. Do i find a good repro harness just for this wire?
Thank
you
greets
« Reply #3 on: January 03, 2014, 09:19:47 PM »
Yes or find an old engine harness with that boot in good condition as a donor
