Author Topic: Power Brake Check Valve Clamp Question  (Read 886 times)
Offline hopeto
« on: December 29, 2013, 12:05:15 PM »
I'm pretty sure that the clamp on the check valve end of the vacuum hose is the "crimp" style. Just wanted to verify and also ask if there is supposed to be a clamp on the other end where it slides on the metal vacuum tube and if it is a crimp type also? Thanks
Original one owner 84 GT Convertible with 1800 miles. 65 Silver Smoke Gray K Code GT Coupe - 65 Cyclone - 67 Vintage Burgundy K Code GT Coupe.  1970 Calypso Corral Boss 302 - 2012 Yellow Blaze Boss 302.
Re: Power Brake Check Valve Clamp Question
« Reply #1 on: December 29, 2013, 01:51:08 PM »
Both ends of that hose were clamped - If it makes any difference engine end first ;)
Offline hopeto
« Reply #2 on: December 29, 2013, 02:59:57 PM »
Thanks, Glad you let me know that engine end first info. ;)
Here' the latest addition to the stable.
Dusk Rose Sports Sprint 289, Automatic, Factory A/C, Power Steering, Power Brakes
Had to add the styled steels - just couldn't live with the whitewalls and hub caps.
