Author Topic: Original 1965 mustang starter solenoid  (Read 4215 times)
Offline 65fastbk
« on: December 24, 2013, 01:39:58 AM »
Hi,
Looking to find an original starter solenoid for my July 1965 sj built car.
It's suppose to be a rectangular fomoco w/ 2701966 on the top? Brown or black body?  Is there a way to tell a repro from an original?
Thx
Offline rockhouse66
Re: Original 1965 mustang starter solenoid
« Reply #1 on: December 24, 2013, 10:06:40 PM »
Here is an original (black body BTW), and I have a picture of this side by side with a new repro somewhere and they are certainly different.  I would love to find one of these NOS as well - good luck with your search!
'66 GT FB
« Reply #2 on: December 29, 2013, 02:26:24 PM »
Black body for your car.
Haven't looked at repos to compare - normally just get an original. Believe some had figured out (purchased a rivet tool) how to remove and replace the large center rivet, so that the mount could be removed and replated. Normally all the is visually poor on originals
Offline rockhouse66
« Reply #3 on: January 06, 2014, 08:51:34 AM »
Here are the repro solenoid and an original side by side.  The repro also has the felt pad on the bottom, which it should not.
'66 GT FB
Offline 65fastbk
« Reply #4 on: January 06, 2014, 08:48:28 PM »
Thanks for the pic!  Were is the felt pad, at the bottom of the unit?  Were the finishes on the originals grainy, there are brown raised specs in the one I have, not to smooth, I will post some pics.
Thx!
« Reply #5 on: January 06, 2014, 11:12:47 PM »
As far as texture of the surface on some of the brown and early black ones the individual fibers can be felt with a finger on others they are very smooth. Miht be a different vendor, batch of material or other production difference
Here is a shot of an early brown style bottom and a 66 - up with the vent and felt filter
« Last Edit: January 06, 2014, 11:14:42 PM by J_Speegle »
Offline 65fastbk
« Reply #6 on: January 07, 2014, 01:57:40 AM »
Great pics!  I don't have felt at the bottom of mine here are a few pics...Not sure if this is a  early or late one, it has brown flakes (bumpy, looks like rust) around it but was originally black
Whats the best way to clean it up? Does anyone restore these?
Offline fast66
« Reply #7 on: January 07, 2014, 02:06:01 AM »
When was the ellips Ford logo changed to the rectangular logo?
thanks,
Claes
6T09K212784
63A 4 25 21B 951384 5 6
« Reply #8 on: January 07, 2014, 02:39:43 AM »
Current understanding is the change from the oval to the block FoMoCo design was during 65 production
There are a bunch of early styles they used including the ones marked
2701966
C4AF11450A (with Autolite & REPCO)
C6AF-11450-A (with Autolite & RBM)  - have one with the "texture" 65fastbk was showing
Then the later C7AF-11450-A1 (with Autolite & RBM)
One provider produced these early upright styes with a plastic bottom using a couple of different engineering numbers
Started putting an article for the site together a couple of years back - got stalled with some other efforts :(
Offline NEFaurora
« Reply #9 on: January 08, 2014, 02:52:39 PM »
Yes, I have seen those with the Black Plastic bottoms...Very weird...and not very common..
:o)
Tony K.
MCA#70001
