Author Topic: date codes on body panels  (Read 1957 times)
Offline silverfox
« on: December 22, 2013, 06:15:51 PM »
Can anyone please enlighten me if there are any reference documents/internet sources to help me in my resto of my '70 Mach 1 - I'm mostly coming across the D0ZB mark, but on occasion I see the attached and I'm confused as I do not know on such occasions if it is original or repro part.
Your help/advice would be appreciated.
Thanks, Chris
P.S. please see attached LHS fender date code for my Mach 1 as an example
Current Mustangs:
1965 Fastback 289 K Code - Hi-Po - Caspian Blue
1970 Mach 1 Sportsroof 351C Auto - White - Project car and in Resto (started Sept 2012)
Past Mustangs:
1966 Fastback GT350 clone, Hi-Po 289, 4 Spd Man, White/Blue
Re: date codes on body panels
« Reply #1 on: December 23, 2013, 11:45:17 PM »
Not sure if I've got the top line worked out
Bottom seems to be month - day of month - stamping plant then shift
Offline silverfox
« Reply #2 on: December 24, 2013, 07:53:44 PM »
Jeff, thanks, the car is 20th May 1970, according to Marti report  - do the marks accord with that timeline ?
Just about to strip off the pass side in enxt few days so I will check that stamp.
Current Mustangs:
Past Mustangs:
Offline jcuprisi
« Reply #3 on: December 27, 2013, 08:34:47 PM »
MustangTek has a vast amount of information. Here is their info on sheet metal.
http://mustangtek.com/FordDateDecoding.html#DCpanelstamping
Offline silverfox
« Reply #4 on: December 27, 2013, 08:54:38 PM »
Many thanks for that link.
Using the tool decodes as 6th may 1970 @ Dearborn ( car build date being  20 May '70) - so looks like the original fender and I'm very happy at that !
Cheers, Chris
Current Mustangs:
Past Mustangs:
