Author Topic: Water Pump  (Read 1046 times)
Water Pump
« on: December 19, 2013, 07:32:30 PM »
      C6OE-A, boxed FoMoCo and no casting date.  Probably came off of a 66, San Jose, 289 automatic.  This is the first, I think, cast ford part I have come across without a casting date.  Have I got a service part, a assembly line part, or no date is the norm for this part ? Thanks,  Brian.
Offline s2ms
    • 6S1757 Info
Re: Water Pump
« Reply #1 on: December 24, 2013, 04:59:18 PM »
The C6OE was replaced in 1968 by the C8 cast body so any C6OE body should be good. They do not have a date code.
What style impeller does it have?
Dave
Re: Water Pump
« Reply #2 on: December 24, 2013, 06:26:09 PM »
     No date is the norm for C6OE-A.  Nothing exciting behind the back plate ?  Brian
Offline s2ms
    • 6S1757 Info
Re: Water Pump
« Reply #3 on: December 24, 2013, 08:13:50 PM »
Stamped steel impeller means it has been rebuilt at least once. Original impellers, and some older rebuilds, were cast iron discs; 4-hole, 8-vane standard pump; 3-hole, 6-vane HiPo pump. It always pays to take the plate off, you never know if a HiPo impeller might be there...
Dave
