Author Topic: hood hinge nut zerts  (Read 4672 times)
Offline Stangman68
« on: December 14, 2013, 03:25:51 PM »
Does anyone know where i can get some new nut zerts (pressed into the rear inner shock tower panel) where the hood hinge fastens to the car.  They tend to pull out....i need a couple to either press back in or weld??  Can't seem to locate a source???  Thanks.  Working on a 1965 mustang fastback..But i believe the nut zerts are same through 70?????
Offline 69bossnut
    • DSD Restorations LLC
Re: hood hinge nut zerts
« Reply #1 on: December 19, 2013, 05:06:08 PM »
Try this link http://www.bigflatsrivet.com/square_nuts.php . I have purchased from in past & worked real well. Good luck.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
« Reply #2 on: December 19, 2013, 08:51:25 PM »
I didn't see a picture of the nut on the web site, so if you are interested in their product, get a full spec sheet.
« Reply #3 on: December 19, 2013, 10:45:58 PM »
............ Working on a 1965 mustang fastback..But i believe the nut zerts are same through 70?????
Nope their different - 65-70 are not all the same. After the somewhat round ones came the rectangle ones that are held in place by the thin sheet metal - not a nut-zert style of hardware.
I've always welded them on the engine side since all work is hidden by the hinge if there is anything to see.
Offline s2ms
    • 6S1757 Info
« Reply #4 on: December 24, 2013, 04:50:54 PM »
How many do you need? I may have a couple...
Dave
Offline Stangman68
« Reply #5 on: January 13, 2014, 12:16:30 AM »
two would be great.  please email stangman68@mediacombb.net we can swap mailing info.  Thanks.  (I have a 69 parts car i was going to cut them out of, but i guess according to Jeff's comment, 65-69 are different????  The car we are working on is a 65 fastback.
« Reply #6 on: January 13, 2014, 02:11:02 AM »
The 65-66 style is a thick round (well almost - one side is flat)  while the 69 is a thinner rectangle shaped (almost square) Both held to the car is a different fashion
Just had to replace one of them on my 69 that had fallen out
 65-67 style
68-70 style
« Last Edit: January 13, 2014, 02:23:01 AM by J_Speegle »
Offline 70 Cougar
« Reply #7 on: January 13, 2014, 02:25:51 AM »
For my 70, I got them through AMK.  They came in a pack of six.  I welded mine in place.  Little dab of seam sealer smooth's it in place.  One thing about AMK, they have a minimum order value of $30...
Steve O
1970 Mercury Cougar
Offline jmlay
« Reply #8 on: January 13, 2014, 09:13:34 AM »
I did not know AMK had them available, great information. As a side note for those who do not know you may purchase AMK products from NPD & there is no minimum purchase.
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
« Reply #9 on: January 13, 2014, 02:49:58 PM »
Yes, but as far as I know NPD  only carry a small portion of the things AMK sells. I don't think NPD carries the hinge nut zerts for instance at least not that I have ever come across in the catalog. I try and get as much AMK stuff as I can through NPD because they ship right away where AMK typically takes 3 times as long.
« Last Edit: January 13, 2014, 02:51:37 PM by Bob Gaines »
Offline 70 Cougar
« Reply #10 on: January 13, 2014, 03:28:38 PM »
Did a search on NPD's website and it appears they don't carry the hood hinge nuts.  Yes, AMK takes a bit longer to ship and I like how NPD has the free shipping on orders over $300.
Steve O
1970 Mercury Cougar
« Reply #11 on: January 13, 2014, 10:43:39 PM »
Ahhhh!  The solution is to buy $300 of hood hinge nuts from NPD and get them quicker/cheaper with free shipping!
« Reply #12 on: January 14, 2014, 12:40:37 AM »
Ah, the impatience of youth, instant gratification grasshopper. A bit of planning and the savings that come from free shipping with a $300 minimum order can add up. Unless of course you have money to toss. As to AMK and their minimum of $30 per order, I again, plan ahead and don't find it too difficult to meet.
Offline s2ms
    • 6S1757 Info
« Reply #13 on: January 14, 2014, 07:50:02 PM »
Email sent...
