Author Topic: Engine and Crank Markings - 65 6 Cylinder  (Read 737 times)
Offline suskeenwiske
  • 214-347-3628
« on: December 13, 2013, 08:48:16 PM »
I found these Markings on my '65 Inline 6 Block and wondered if anyone knows what they signify. The 5 1 1 Marking appears twice on the Block and once on the Crankshaft.
Ray
« Last Edit: May 18, 2020, 06:33:24 PM by J_Speegle »
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Re: Engine and Crank Markings
« Reply #1 on: December 13, 2013, 09:21:49 PM »
Looks like a job number for a rebuilder. Guessing that the engine did not have a standard bore or standard crank
  • 214-347-3628
« Reply #2 on: December 14, 2013, 12:53:51 AM »
The Engine had been bored out 40 over and the Crank, (original Ford), had the Main and Rod Journals milled down 10 thousands, so definitely rebuilt sometime in its history. No matter...thought I'd ask in case there may have been some factory significance to the marks.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #3 on: December 14, 2013, 01:50:13 PM »
Think that some of those stampings (not that familiar with 6 cyls :(  are factory but can't tell the new ones from the old. Likely one of those other stampings would be the date the block was machined if they followed the same pattern as the V8's and put them on the oil pan face
