Author Topic: 1973 valve cover  (Read 2195 times)
Offline rcg301
1973 valve cover
« on: December 09, 2013, 09:18:25 PM »
Did the valve covers for the 351C have the "Power by Ford" or not?  Was it painted the dark blue or lighter blue?
Re: 1973 valve cover
« Reply #1 on: December 10, 2013, 02:14:54 AM »
First welcome to the site - hope you find the site and information useful
Don't' know what light and dark blues are - should be Ford Corporate blue
As far as the valve cover pressings, not sure if they changed during the year - but you didn't provide when your car was built :(
Its a good idea to include when, where, body type, and options in your signature or include it in every request or you'll simply get asked for it over and over again ;)
Looking through my pictures I've got an original spring and later unrestored 73 cars with the Ford oval (No power by Ford)
Offline nham3407
« Reply #2 on: December 10, 2013, 10:22:06 AM »
Here is a May 1973 untouched 183 mile convertable valve cover no stamping on the cover at all.  I am finishing the restoration on a 11/71 Cleveland that does have the Powered By Ford stamping.
Wrong first picture, but I will leave it in case you need a part number for the air cleaner. :)
« Last Edit: December 10, 2013, 10:24:32 AM by nham3407 »
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
« Reply #3 on: December 10, 2013, 03:13:23 PM »
Seems that the valve covers were stamped with the Powered by Ford in 71-72 and then they changed. Just not sure at this point if it was with the change from 72 to 73 or a running change during the production year.
Will post the clearest one I've got of the Ford oval - its stamped to the right to what you have in your second picture
Offline rcg301
« Reply #4 on: December 10, 2013, 07:51:15 PM »
sorry, forgot about that. My Mustang was built on May 30, 1973.  Mach 1, medium yellow, 351C, 2V, C6 transmission.   Thanks for the info.
Offline rcg301
« Reply #5 on: December 10, 2013, 07:57:18 PM »
So for a concours valve cover , on my car, would it be acceptable to have a Ford circled stamped on the valve cover? or was that only for certain years?
« Reply #6 on: December 10, 2013, 08:06:31 PM »
You would have to check with the organization your were going to have the car judged at the and that head judge. They should ask you for documentation (why you choose that style) and or you should offer it BEFORE any judging took place
Here we would rather focus on what (given our best efforts) on what was original rather than where each judging organization is at this moment since it can take them a while to catch up sometimes  :-\
Here is some additional pictures that might help you in your efforts. Wish the pictures was clearer but thing this should work with some additional homework on your part. Good thing that there are a ton more unrestored 73 out there than 71 or 72's ;)
An April example I believe the oval can be barely made out (upper left hand corner of the oval)) where the arrow shows
And a June example showing the oval clearly
Though they don't look like it they are pictures of two different cars :)
« Last Edit: December 10, 2013, 08:38:56 PM by J_Speegle »
Offline nham3407
« Reply #7 on: December 11, 2013, 10:16:58 AM »
After viewing Jeff's feedback I went back through my pictures of the convertable.  I did find one picture that showed the Ford oval stamped on the valve cover much like Jeff's example.  I have attached it below.  Given this was a May 73 production date similiar to yours I would think the Ford oval would be correct.  This car is a 351 2V with C6 as well.
Offline jeff8877
« Reply #8 on: December 30, 2013, 11:28:30 PM »
Hello,
My June 73 Mach has the Ford stamping on both valve covers.
Jeff
