Author Topic: 65 Mustang 9 inch backing plates  (Read 3953 times)
Offline 65fastbk
« on: December 08, 2013, 04:31:45 PM »
Hi,
Im just had my axle bearings replaced and was about to start cleaning up the backing plates...These are the numbers I see on each backing plate:
70398 k/h
70399 k/h
Is this correct for a 65 nine inch?
Thanks!
Offline suskeenwiske
  • 214-347-3628
Re: 65 Mustang 9 inch backing plates
« Reply #1 on: December 08, 2013, 05:45:39 PM »
Though from a 1966 Fairlane, it has a 9" Differential and the Backing Plates are marked 70398 and 70399 as follows:
70398   70399
   KH        KH
This may lend some credence but we'll need an expert to confirm that your numbers apply to your specific application.
Ray
« Last Edit: December 08, 2013, 06:13:01 PM by suskeenwiske »
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline 65fastbk
« Reply #2 on: December 08, 2013, 05:53:45 PM »
70398   70399
   KH        KH
This may lend some credence but we'll need an expert to confirm.
Ray
Thanks. What should a 65 mustang backing 9 inch backing plate be?
70867 k/h
70866 k/h
This is a July 65 k car.
  • 214-347-3628
« Reply #3 on: December 11, 2013, 10:21:00 PM »
I don't know for sure what the correct numbers are, my example was from a different car and year. For all I know, the Fairlane may have had a rear end change.
I don't know what the new numbers you posted are from...we really need an expert in on this one, hopefully someone will reply.
Sorry, wish I could be of more help.
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
« Reply #4 on: December 11, 2013, 10:50:53 PM »
70867 k/h
70866 k/h
The 70866/70867 are Kelsey/Hayes numbers. Those equate to backing plates for 10 inch drums with 1-3/4 inch brake shoes. 10 inch drums can be found on 8 or 9 inch rear ends from various years on various Fords.
The 71085/71086 are Kelsey/Hayes numbers. Those equate to backing plates for 10 inch drums with 2 inch brake shoes. 10 inch drums can be found on 8 or 9 inch rear ends form various years on various Fords.
Offline sgl66
« Reply #5 on: December 17, 2014, 05:43:39 PM »
70867 k/h
70866 k/h
+1
From Oct 65 k car.
Not only backing plates but also KH/Ford stamped parts...whatever these are called
RH 47852
LH 47853
The piece that goes between both sides is 47855
