Author Topic: 1968 GT 500 KR Rear Brake Lines  (Read 6028 times)
Offline dwdshelby
« on: December 04, 2013, 01:31:57 AM »
Hi, I have searched the website for this but didn't find any info ... but I recall reading somewhere that the rear brake cylinders on the 1968 KR were the same units on both sides (C7ZZ 2262 which is the left one in the general mustang parts books). Is this true? I have two of these but then the next question is where to source a good set of rear brake lines that would fit and that are cosmetically correct? My originals are pretty dirty and stained especially the wire wrap guards. Baring sourcing some new or NOS lines, is there a way to restore the originals to reuse? Otherwise, they are not bent or damaged.
Thanks for all your help.
Dwdshelby
Offline TLea
Re: 1968 GT 500 KR Rear Brake Lines
« Reply #1 on: December 07, 2013, 08:07:00 PM »
all 68 shelbys use the C7ZZ A cylinders on both sides.
no real way to restore brake lines but reproductions are decent. confusion comes the way catalogs list the lines because most use 28 spline line sets even though all have 31 spline axles. is your car a 4 spd or auto?
« Reply #2 on: December 07, 2013, 08:20:55 PM »
Thanks Tim :)
Offline dwdshelby
« Reply #3 on: December 08, 2013, 06:56:18 PM »
Hi, thanks Tim.
It is an auto car.
Best
Dwdshelby
Offline TLea
« Reply #4 on: December 11, 2013, 10:49:18 PM »
Automatics use the 28 spline brake line set with the C7ZZ 28 spline brake hose
« Reply #5 on: December 12, 2013, 09:11:02 AM »
Would that be true on a automatic 68 GT 350 as well?
Offline TLea
« Reply #6 on: December 13, 2013, 06:41:12 PM »
Yes. All 68 Shelbys are the same 28 spline line/hose set (even though they are 31 spline) except KR 4spd which uses the 31 spline set
« Reply #7 on: December 15, 2013, 10:33:32 AM »
Boy that is confusing looks like I will be making a return. Thanks Tim
« Reply #8 on: December 15, 2013, 01:08:17 PM »
Not really confusing the 68 1/2s & KRs with 4-speed have rear staggered shocks & vent hose is moved to outside more & brake hose moved inside more having 2 separate holes for exhaust pipe clearance around staggered shock mount & special brake hose & brake line bends routing different.
« Reply #9 on: December 15, 2013, 05:00:14 PM »
The author has a Automatic not a four speed  .
« Reply #10 on: December 15, 2013, 10:03:36 PM »
Ok I guess I am a little slow. What is confusing to me is if all 68 Shelby's are 31 splines why do they use the 28 spline line and hose sets?
Offline 69bossnut
    • DSD Restorations LLC
« Reply #11 on: December 16, 2013, 12:01:44 PM »
dwdshelby,
I am reproducing the correct single crimp brake hoses. I have both the C7 rear & the C8 rear hose. For your car being a 4 speed it will use the C8 hose. For the fronts I only have the hoses for disc brake cars at the moment. I also have the correct 1/4" small bleeder wheel cylinder for your car. All my contact info is in my signiture below. You can check out the hoses on my website listed below as well.
Let me know if I can help.
David
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
Offline TLea
« Reply #12 on: December 17, 2013, 08:47:43 AM »
Its really not confusing, its the way the vendors advertise. 28 or 31 spline has nothing to do with the brake lines but thats the way they advertise them. It should be sold as,
1. 68 Mustang/Shelby 9" rear axle brake lines, all except 428 CJ/KR 4 spd
2. 68 Mustang/Shelby 9" rear axle brake lines 428 CJ/KR 4 spd
Like Ed said its the relocated axle vent of the staggered shock not the spline
Offline TLea
« Reply #13 on: December 17, 2013, 08:52:05 AM »
dwdshelby,
David
David, his is an auto which uses the C7
To anyone who doesnt know David, he makes some much needed very high quality reproduction parts and is a pleasure to deal with. In addition to the hoses and wheel cylinders he also makes beautiful strut rod bushings, rear axle line straps and many Boss 302/Boss 9 parts.
« Reply #14 on: December 17, 2013, 10:19:21 AM »
+1 on davids parts & he was at shop recently getting brake hoses for early cars he is working on making CONCOURS correct also.  I forgot (in my post) the rear brake line to brake hose strap holder being different (longer) on 68 1/2''  4-speed cars right TIM?
