Author Topic: 66 washers on water pump  (Read 2757 times)
Offline 66RavenGTCoupe
« on: December 03, 2013, 02:44:52 AM »
Hi all,
There are two thick washers on my 66 water pump and my mechanic can not remember which bolts they should go on. He's completing assembly on Thursday for paint so any help here would be great.
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline Herman
Re: 66 washers on water pump
« Reply #1 on: December 03, 2013, 04:07:53 PM »
Hi Dan
Do you have any photos of the washers to assist everyone with your question.
regards
Herman
Washing, polishing and cleaning stuff some more in an attempt to retain that 'Golden nugget'
« Reply #2 on: December 03, 2013, 04:59:06 PM »
If you look closely you can see one that is to the right (clockwise) of the fuel line bracket on this 56 mile car. Just wondering where the other one goes now.
Dan.
« Last Edit: December 03, 2013, 05:08:59 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #3 on: December 04, 2013, 12:16:06 AM »
The upper washer is as you determined, the lower washer goes on the place bolt just above the timing mark. It is there but barely visible. For reference, there are two other bolts shown in the picture between the upper and lower bolts that get the washers.
« Reply #4 on: December 04, 2013, 01:37:37 AM »
Thanks Jim,
In my research today I had just found out that these washers act as a spacer for non power steering cars. This avoids the need for different length bolts. The two positions mentioned are where the ps bracket would mount and according to the AMK sheet that comes with the bolt kit, the washers should be omitted for a ps installation.
Thanks for your help.
Dan.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #5 on: December 04, 2013, 03:14:28 PM »
Now that is some interesting and little known stuff.  Looking at my manual steering car the pump seems to have eleven bolts with washers.  Brian
« Reply #6 on: December 04, 2013, 03:28:12 PM »
Thanks Jim,
In my research today I had just found out that these washers act as a spacer for non power steering cars. This avoids the need for different length bolts...........
+1
« Reply #7 on: December 04, 2013, 03:57:03 PM »
Hi Brian,
According to the AMK sheet the 3 top bolts and 2 inner bolts are a slotted hex head and have spring washers and the 4 bottom bolts are a flanged head. This is for a 66 no AC with PS car. (Cast pump) Hope this helps.
Dan.
« Last Edit: December 04, 2013, 04:01:21 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #8 on: December 04, 2013, 06:44:42 PM »
From my notes.
« Reply #9 on: December 04, 2013, 11:55:55 PM »
Great info Jim. Straight into my file!
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
