Author Topic: Undercarriage slop paint - Dearborn June 3rd 69  (Read 3357 times)
Offline 69eliminator
« on: December 03, 2013, 12:57:29 AM »
Can someone post some photos of the slop paint used on Dearborn built cars around the first week of June 1969?  The prior owner remembers then Cougar I'm restoring having a black undercarriage covered mostly by the body color almost to the tunnel. He says he has photos of the undercarriage but hasn't been able to find them. I have the car to the point where I am ready to start painting the bottom and could use some help/ advice on how to proceed as accurately as possible
Brian
« Last Edit: December 06, 2013, 10:09:05 PM by J_Speegle »
1969 Cougar Eliminator 428 CJ Q Code with AC , PS, PDB, C6 Transmission,Traction-Lok Diff. 3.00. Bright yellow paint.
Dearborn 6/69
Re: Undercarriage slop paint
« Reply #1 on: December 03, 2013, 11:40:13 AM »
Brian
Details like the under side color are not something important back then that many people would remember correctly.Most likely the PO is remembering a darker gray. Typically regardless of other paint it was mixed with it the shade would be some kind of gray-blueish gray,greenish gray,dark gray etc. A picture on a monitor will only give you a general idea. Hopefully Jeff with his vast picture library will be able to comply.You will not get it exact unless you had a panel from a car made that day and even then it may be different if they were changing over to another tank. If all else fails I would suggest a medium to darker gray with a little metallic mixed in (one of the many possible ingredients)  .That seems to be a more common variation. It is hard to get wrong . It most likely could have changed by the day or week given the nature of the batch paint (mixed up unused extra colors ) . Something reasonable is usually the best you can hope for if the original panels have already been striped. That is all a reasonable concours judge would expect given the nature of the product.
« Reply #2 on: December 03, 2013, 07:28:21 PM »
Like Bob posted the best place to look fro what color was being used was your original floor pans but as you report that resource is long gone :(
Being such a late car it could have been IMHO a red oxide car (from firewall rearward) but if you choose to rely on the prior owners report (you really don't have allot more to go on at this point) then we'll compare batch color from that period
If we knew the specific cay you car was completed on and we had another original example from that same day - we would have a better system to gather info from but unfortunately I haven't collected all that many from every week/day as of yet ;)
Will go through my picture for June 69 Dearborn and report back
« Reply #3 on: December 03, 2013, 07:35:14 PM »
Thanks for all your help.
The car was built on June 3,1969.
Best
Brian
Dearborn 6/69
« Reply #4 on: December 03, 2013, 11:11:11 PM »
Just for the heck of it what VIN number would that make your car (only want/need the first four numbers ex. 5162xx)?  I've got some pictures from Cougars but they are more difficult to date since I don't have allot of books or data that helps like I do Mustangs and Shelby's. Might have some additional shots to share from that pile also .
« Reply #5 on: December 04, 2013, 07:27:15 AM »
Hi Jeff
5784xx
I sent you a PM as well
Brian
Dearborn 6/69
Offline calypso
« Reply #6 on: December 04, 2013, 10:09:26 AM »
Jeff,  are you saying that late build cars (mine is a July 70 Dearborn) could have been red oxide instead of slop??
« Reply #7 on: December 04, 2013, 03:27:00 PM »
Your car would not be a "late build car" in this discussion  since yours is a 70 not a 69 - the focus of the question posted ;)
Different year makes all the difference  :D
« Last Edit: December 04, 2013, 03:31:07 PM by J_Speegle »
Re: Undercarriage slop paint - Dearborn June 3rd 69
« Reply #8 on: December 06, 2013, 10:52:37 PM »
Looking at the pictures I do have from Mustangs around the 9F196xxx period and the limited Cougars around the same time I offer the following since the poster lacks any original clues - next best choose at this point IMHO
Anyway looking through everything we got lucky and I happened to have to samples cut from cars from about that period. :) Here is a scan of them. Right one is in much better condition since it was under the sound deadener ;)
Looks like the fairly typical dark gray batch with a tilt towards blueish green. I've used a dark gray VW gray exterior color in the past and tinted it to blueish thing it would work in this car also with maybe a little white (very very little) but would have to see what the green did to the mix first ;)
Also notice on the sample on the right you will see the sound deadener which would have been sprayed on your car over the batch color. Typically looks to be three passes front to rear from the center of the car (worker standing under trans and walking down the drivelien tunnel) starting just behind the torque box area on the sides and behind the trans in the center. Driveline and exhaust was not installed on the car at this period from what we find. All stop or fade away before the rear end rise in the floor board typically
« Reply #9 on: December 08, 2013, 12:22:47 AM »
Thanks Jeff,
Really appreciate  all the help.
Brian
Dearborn 6/69
