Author Topic: 69 driver side front floor pan  (Read 1661 times)
Offline Rsanter
« on: November 30, 2013, 01:03:37 AM »
on the 69 conv an underside inspection today shows that I have a little rust in the floor.
not bad but a section of about 6x6 will need repaired/replaced.
so, does anyone make a correct floorpan for the 69s?
does anyone out there have a donar car they can cut a piece from?
the welding is not a problem, that I can take care of but this car has to be right. it is a sort of survivor car in that we have not done that much work to it for the mileage it has and when we have worked on it we have done so as kind as we could
bob
Bob
68 mustang conv basket case
69 mustang conv 302 AT
priceless
  • Guest
Re: 69 driver side front floor pan
« Reply #1 on: November 30, 2013, 09:05:43 AM »
Try some Mustang vendors, i.e., NPD, CJPP. Go to Ebay.  Hope this helps.
Offline jmlay
« Reply #2 on: November 30, 2013, 10:23:35 AM »
What specific area needs repair? A 71-71 floor pan is nearly  match to the 69/70. The difference is the frame rails in a 71-73 are wider so the "fingers" as I like to call them do not extend as far to the center of the floorpan. So depending on what portion you need to repair there are options.:
http://www.npdlink.com/store/images/products/407-8-1rh.jpg
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline Rsanter
« Reply #3 on: November 30, 2013, 12:30:33 PM »
The area that needs to be replaced is between the frame rail and the rocker and right in front of the seat pan.
The area is largely flat where the obvious rust is but gets right up to where the beads in the floor is so I am sure those will be thinner than desired
I suspect that it frm leakage where the top, the windshield post and the door class met. For years this area would drip a little and there was no replacement rubber available for years. Now there is from what I hear
Bob
Bob
Offline Wade429
« Reply #4 on: November 30, 2013, 01:44:01 PM »
Contact Kevin Manley at Kevin's Klassics in Minnesota.  He has the correct floor pan piece you need.
Wade
« Reply #5 on: November 30, 2013, 06:37:19 PM »
Depending on which section your looking to replace the standard repo does not match the pattern and shape of the originals Try Kevin (mentioned above) and the article in the library related to your issue ;)  That's why they are there. This article was provided and written by Pat Wahlen a member
http://concoursmustang.com/speegle/Articles/Article%20-%20Floor%20pan%20fix%20-%20Pat%20Whalen%202-13.pdf
