Author Topic: 66 GT Front Grille and Fog light bracket Finish?  (Read 2433 times)
Offline 66RavenGTCoupe
« on: November 29, 2013, 06:06:14 PM »
Hi all,
Did a bit of a search and could not turn up an answer here. The colour is black of course and could have sworn that my originals were a satinish finish but was told by one of our leading judges that it should be semi gloss.
Can anyone help please?
Dan.
« Last Edit: December 03, 2013, 02:54:26 AM by 66RavenGTCoupe »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: 66 GT Front Grille and Fog light Finish?
« Reply #1 on: November 29, 2013, 11:07:32 PM »
Hi all,
Dan.
Maybe it is just a matter of sematics ? Satin and semigloss are two very similar descriptions for the not gloss and not flat finish.
« Reply #2 on: November 29, 2013, 11:35:53 PM »
Thanks for the reply Bob. For the sake of clarity I will change my description from satinish to flat black. :) can you tell me what it should be please?
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #3 on: November 30, 2013, 12:28:23 AM »
Semi-gloss or satin is correct, flat and gloss are not. Everything on the grill including the rivets are painted. I would try to find at least three different semi-gloss shades, one for the engine compartment, one for the grill and one for brackets, engine, hood latch, battery tray. The latter should be the shiniest. There's no reason, the differences are a nice detail. Keep in mind that most brackets were dipped.
PS: The back side of the corral is almost a flat black.
« Last Edit: November 30, 2013, 12:32:07 AM by jwc66k »
« Reply #4 on: November 30, 2013, 04:05:09 PM »
Thanks guys painting parts today!
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline sgl66
Re: 66 GT Front Grille and Fog light bracket Finish?
« Reply #5 on: September 08, 2016, 12:16:00 PM »
what was the original finish on the fasteners that hold the fog light bracket to the grille?
« Reply #6 on: September 08, 2016, 04:42:41 PM »
If you go to the Library section of this forum and open post "Mustang Hardware Spreadsheets 64-66" you find two spreadsheets, one by part number, the other by application. Some surfing in the latter spreadsheet will give you your answer, part number and finish code.
You might consider some source document for your car's year like the Mustang Assembly Manuals.
Offline sgl66
« Reply #7 on: September 08, 2016, 05:52:27 PM »
Thanks Jim,
Row 2164 calls out 42127-s8 (zinc) and this thread http://www.concoursmustang.com/forum/index.php?topic=9375.0 references RBW used for ground and an s2 finish. The 6 screws holding on my brackets are all RBW marked so guessing phosphate?
« Reply #8 on: September 08, 2016, 07:29:01 PM »
Using the teachings of the Majha Jeff, it may be a case of plant specific hardware for the head marking in this application. My three San Jose cars all had CF head markings and they were all zinc plated. It seems Metuchen used a different supplier. The electrical assembly manual calls out zinc finish independent of head marking, so a clear zinc finish would be appropriate.
