My first attempt at installing my fastback door glass into the channels failed. The glass wasn't tight enough in the channel and I was able to pull it back out with my hands and moderate force (i.e. the glass didn't *fall* out, but I didn't need a block and hammer to remove it). The stainless steel trim/molding held much better, requiring a block of wood and dead-blow hammer to persuade it to come off again.
I need help/tips to retry setting the glass into the channel.... doing something different so that it stays tight. I suspect either I need different or thicker seal strip or I need to slightly narrow the window channel openings.
I watched this video several times before attempting this task:
I'm using NOS glass and restored original channels and molding. I removed the original glass from the channels myself and it was VERY difficult to remove the glass. With that said, is it possible that I need to very slightly tighten/close the window channels (using a bench vise) to render a more mechanically sound fit?
I bought the seal strip from NPD. Is there another product you guys would recommend? The stuff from NPD didn't stick to my (clean) glass at all. I gently applied low heat from a heat gun and after 10 minutes or so of alternating heat and pinching by hand, I was able to get the seal strip to form to the glass long enough to attempt installing the channel (first) and stainless molding (second). Perhaps the seal strip from NPD isn't thick enough?
Any other help you guys could give me would be appreciated. Other than watching the above video, I'm not familiar with this process. As described in the video, here's what I did:
(1) aligned the window channel & glass using a straight edge and marked the glass so that I knew where the channel needed to line up so that the molding would go on properly
(2) Applied the seal strip to the bottom of the glass
(3) Using the mark I made in step #1, I used a rubber mallet to gently pound the glass into the channel
(4) Applied the seal strip to the stop and side of the glass
(5) I used a rubber mallet to tap the stainless molding to the glass
Seemed to work, except I could feel the glass wiggling in the channel and the trailing edge of the stainless molding didn't seem to be on all the way
