Author Topic: 1967 FB tail-light wiring harness  (Read 6114 times)
Re: 1967 FB tail-light wiring harness
« Reply #15 on: November 29, 2013, 04:16:57 AM »
I had no idea that the wiring looms had i.d. tags. Does anyone have any pictures?
Sorry not real clear examples - what was handy
Normally one to ID the application (these are not from a 67 application) and another for the assembler of the loom
ECS makes some of these as decals for the 69-70 crowd or you can make them yourself if you have the time. Not a quick thing to do ;)
Offline Paperback Writer
« Reply #16 on: November 29, 2013, 11:35:42 AM »
I realize this thread is for 1967 Fastbacks, but I thought these shots of my original 1967 Convertible tail light harness might be useful.  The car was built in San Jose on Sept. 22, 1966...
1967 390 GTA Convertible
7R03S110###
« Reply #17 on: November 29, 2013, 08:09:49 PM »
Should apply - thanks for adding a 67 specific to the discussion. Your example aslo shows the label and assemblers label as mentioned
« Reply #18 on: November 29, 2013, 09:20:22 PM »
That tail-light harness is in very good condition, far better than what I normally see throughout my cores and turn-ins for refurbishment.
Offline tim_morrison82
    • Click Here for My Project
« Reply #19 on: November 30, 2013, 01:21:52 AM »
my 68 tail light harness rotted away in the areas not visible, and was completely fine where visible... i thought that was quite odd...
« Reply #20 on: November 30, 2013, 09:55:50 AM »
Actually that is quite common. Those areas hold moisture and give shelter to mice. If the quarter is rusted I would guarantee that it is rotted off.
« Reply #21 on: January 15, 2018, 06:15:39 PM »
Since my back is out and I can't do anything really useful, I decided to start replicating wire labels for my SJ fastback (see sig).
I've noticed a lot of interesting things:
The instrument panel wires have a green FoMoCo label with part numbers and a white assembly label.
The FoMoCo tag is fairly narrow (0.725 or less), so the C7ZB is on one line, the part number of 10B942 is on another.
The assembly label is slightly narrower at about 0.625 and reads:
JAN
DAY
TSX
in a repeating pattern. The text is not straight and could be a stamp. Not sure what DAY means, but it might be the assembler's initials. JAN appears to be for January, since all other items on the back of the dash panel also read 01 or A.
I only mention the instrument harness as it's very well preserved and original.
The main under dash harness is red tape with a yellow label over the top. The assembly label is within an inch of the Ford part number tag. both labels are about the width of the instrument panel labels.
The tail light harness on my 67 fastback was red but has disintegrated and cannot be read. However, what is left is the same width as the instrument panel harness Ford id label.
When I replicate this label it will also be red, have C7ZB on one line and 14405-A on the next.
If I follow the pattern of the instrument panel label for the tail light harness it should read:
TSX
C7ZB
14405-A
FoMoCo in a rounded box
repeat the pattern.
A parts car I have that is within a few thousand VINs at SJ as well and has this label format for the tail light harness, but in white:
S.X. -A
C7ZB
14405-A
repeat the pattern.
I have found no assemblers tape on any of my tail light panel harnesses, but they are not unmolested like the Paperback Writer harness.
The pics below are from my 67 SJ parts car dated Mar 6 1967.
« Last Edit: January 15, 2018, 06:25:42 PM by Bossbill »
« Reply #22 on: January 15, 2018, 07:00:17 PM »
Sorry your laid up - age brings with it pay back for all of our earlier and current choices as well as experiences.
Doing wire labels is kind of fun once you draw all the different logos and figure out/make all the letters and numbers - building a took box of sort that you can mix and match.
All the different colors and types of paper is a pain/film to locate though if you can find them
Remember that your taillight label will be different from a 67 Mustang FB label Correction (thanks to Mr Gaines for reminding me) For this year they would be the same.
« Last Edit: January 15, 2018, 11:57:56 PM by J_Speegle »
« Reply #23 on: January 15, 2018, 11:15:10 PM »
I've had back issues all of my life, but it seems to happen more often.
The '75 MPC skips over 67 as far as part numbers goes.
it goes straight to 68 which shows a 14405-A basic part number.
Why is that? A Shelby wire harness should be a standard fb harness, albeit with a traveler for a trunk light. The Shelby parts are simply grafted onto the harness. The MPC does show a part number for the Shellby/Cougar extensions.
Here is the JPG for a standard dash label and assembly label, if anyone wants to play around with it. It includes text alone, color alone and the merge of the two as well as the assembly label for an early 67 SJ car.
[edit -- use different jpg file for color labels]
« Last Edit: January 16, 2018, 12:49:16 AM by Bossbill »
« Reply #24 on: October 13, 2018, 07:42:31 PM »
PaperbackWriter's post
with pic "05 - Tail Light Harness.JPG", shown above, calls out "Unknown" on the far left.
This is the rear quarter panel's interior light female plug. The right quarter panel light is a single line that travels from the passenger side A-piller, through the side sill and to that side's light.
