Author Topic: Identifying FW holes  (Read 4753 times)
Offline livetoride60
Re: Identifying FW holes
« Reply #15 on: December 06, 2013, 04:37:47 PM »
Thanks again Jim.
Well it gets more interesting.  Found a few more holes under globs of sealer.  Two above the heater and one below.  See pics.  Both are filled with what looks like original dum-dum or some sort of sealer.  The larger one on the bottom looks punched from the inside-out.  The two smaller ones above the heater look punched from outside-in.  You can see the curled back points of the punching (I assume) like on other FW holes in the last picture.
Any ideas?   ;)
« Last Edit: December 06, 2013, 04:46:51 PM by livetoride60 »
« Reply #16 on: December 06, 2013, 10:48:57 PM »
Any ideas?   ;)
If this is the San Jose K code - nope. Since they are not present on other examples
Here are some other examples from around your cars time period
« Reply #17 on: December 06, 2013, 11:18:16 PM »
Is this a test? This looks like a case of the engine ground to firewall screw either stripped out of the firewall or lost, and the quick fix was a 1/4-20 nut for both the two speed ground as well as the ground.
« Reply #18 on: December 07, 2013, 01:13:23 AM »
A test - maybe for someone. Not my job to figure out why PO's do certain things to their cars ;)
But good you mentioned it before some lurker thought that was original - like the tie rod location in picture #3 - that is not where that goes either   ::)
