We enough parts to build about 25 428 CJ engines a couple of 428 SCJ engines. These engines will range from 8995.00 to about 11,995.00 depending on the date codes, bore size and the parts used to rebuild them. They all will be dyno tested with the camshaft broke in. dye checked for leaks and all bolts re-checked and the paint touched up after they are run in. They will have a 2 year/ 24,000 mile warranty on them on all internal lubricated parts. We do about 80 FE engines a year from all aluminum to restoration engines. We keep all sorts of date coded orignal 428 CJ/SCJ engine parts. Call Keith Craft at 870-246-7460.
Thanks, Keith Craft
