Author Topic: 1970 competition suspension coil springs  (Read 1437 times)
Offline 70Twister
« on: November 13, 2013, 10:53:59 PM »
I need to know whats the difference  between the 1970 competition suspension coil springs and regular Mach 1 coil springs? And where can I find a set of the correct  competition suspension coil springs? Thanks
70Twister
351C Dearborn Build date 10/13/69
Re: 1970 competition suspension coil springs
« Reply #1 on: November 16, 2013, 07:46:03 PM »
Don't have a 70 MPC and the later versions only show replacement springs and only lists "Standard" & "Heavy Duty springs".  Of those there are 6 different springs listed and applications are only 302 2V & 351's
Likely the spring rate is higher and the final height different.
Example (hope the MPC listed them years later)
Standard spring with no options on a 351 convertible - just for comparison
Standard = 1520 lbs.,  .600 wire dia and 16 1/4 "
Heavy Duty = 1500 lbs.,  .625 wire dia  and a height of 14 3/4"
On place to find an exact replacement would be from a donor car with the same options and body style from the same time period since it appears that the front springs changed early in the production year
Offline 70Twister
« Reply #2 on: November 16, 2013, 10:05:39 PM »
The springs that are in my car have a wire size of .675 best I can tell.
Do you have any listed like that? One of the springs are bad so I'm need to find some replacements. Thanks
70Twister
« Reply #3 on: November 18, 2013, 09:59:55 PM »
Checked the 72 version listing what was available and what Ford was carrying at the time and biggest ones listed for 70 were for 428 all bodies with AC & PS (in some bodies just AC) with 6 1/2" dia wire and only 8 3/4 coils
MPCs after the production date are not my favorite resource - again we have no idea if this is what was used originally
