Author Topic: mixed up some fasteners help  (Read 1258 times)
Offline original68
« on: November 12, 2013, 12:10:01 AM »
hello all i have a 68 fastback and mix up some baggies during disassembly.  tried to id the bolt in photo #1 it has a unique washer and the AMK part that it looks identical to # is 384931-s. i tried to cross reference this # in the assembly manual with no luck and picture #2 the metal bracket i can't remember where it goes or any of the pictured fasteners .  i thought under the dash. can anyone help id where these parts go. thank you for all your help
ok found all of picture#2 they are attached to brake peddle bracket
« Last Edit: November 12, 2013, 01:22:45 AM by original68 »
Re: mixed up some fasteners help
« Reply #1 on: November 12, 2013, 12:33:43 AM »
The bracket holds the flasher and attaches to the dash support. The small screw should attach it. I think the hair pin retains the pulley pin on the E brake. The  three bolts and nuts may attach the bracket that the clutch return spring hooks on also on the dash support the nut could retain the E brake to fire wall. should be two. My best guesses.
 I just hate that when you have extra parts! LOL
« Reply #2 on: November 12, 2013, 10:35:28 PM »
Don't recall any of the bolts shown in picture #1 on a 68. HAd some similar ones on a 71
« Reply #3 on: November 12, 2013, 11:50:57 PM »
The bolt in picture 1 is typical of those used in 1971 thru 1973 in the engine compartment for body parts. As to the rest, a diameter, threads per inch and length would be beneficial.
Offline original68
« Reply #4 on: November 13, 2013, 12:18:55 AM »
the bolt is 1 1/8 long and is  5/16- 18 threads
« Last Edit: November 13, 2013, 12:20:30 AM by original68 »
« Reply #5 on: November 13, 2013, 04:05:37 PM »
That bolt was not used on your Mustang, the lock washer style was the giveaway. It was the others that I requested some dimensions so I can possibly provide an application.
Offline original68
« Reply #6 on: November 16, 2013, 05:17:15 PM »
thanks jim i will put them aside
