As suggested in the past check with Auto Color Library/TCPGlobal.com and see if they have match you needed color to the current available paints.
They will have a page with all the original color paint chips and links from there
Been very helpful in the past with this sort of thing
Thanks! I did find my way to that page, but it may have created as many questions as it answered, lol.
http://www.tcpglobal.com/aclchip.asp...-Ford-pg02.jpgThere are four choices for a given color. Do I want acrylic enamel? Acrylic urethane? or something else.
How do I know if this pain is configured with the right flatness? Based on Charles post, I do need to add something to make it semi flat, and unless I can find concepts and mix to eggshell, experiment/guess to figure out how much?
If I select acrylic enamel, I get two options "restoration shop" paint, or PPG Delstar DAR.
Acrylic urethane has no PPG option.
If I select Urethane Basecoat, I get two options, "restoration shop" paint, or PPG Deltron 2000 DBC. Going base means I'd need a clear, I think, and have to guess about the amount of gloss in the clear? It seems like the BC/CC would be more likely to obscure the pressed in grain in the doors and fiberglass panels.
In any case, none of the PPG options on TPC's site are called "Concepts". Charles do you know what "Concepts" is? Urethane, or enamel? If I just bring the PPG red code 71315 to the local PPG place and ask for that color in concepts, with the matting agent you mentioned and hope they know what I mean?
Thanks for all the help!
