Author Topic: Roof Console Removal, '67 Coupe?  (Read 2887 times)
Offline drummingrocks
« on: November 10, 2013, 08:56:42 PM »
I need to change the front and rear windshield gaskets on my '67 coupe, and I figured while I was at it, I might as well replace the headliner as well.  The car came with a factory overhead console, and try as I might, I have no idea how it mounts, or how to remove it.  I sure don't want to damage it!  Thanks for the help!
Offline Oz390
Re: Roof Console Removal, '67 Coupe?
« Reply #1 on: November 10, 2013, 11:42:15 PM »
Should be two screws at the rear, and two at the front.  Lower gently, as there shuld be a short ground wire attaching it at the front to the roof/bracket and the main feed at the rear (from the original dome light pug).
You will need to install the front braket before the headliner (well, you may not "have" to but it is easier) and then cut it a bit to install the console, room for the lights to poke up...
« Last Edit: November 10, 2013, 11:46:15 PM by Oz390 »
8R03S : 76A I 2A 15M 72 5 U
Offline Oz390
« Reply #2 on: November 10, 2013, 11:45:33 PM »
front bracket
rear mounting holes...
(from a 68, should be the same)
HTH
priceless
  • Guest
« Reply #3 on: November 11, 2013, 09:18:39 AM »
+1 on Oz390. Exactly like our '67.
« Reply #4 on: November 13, 2013, 11:57:16 AM »
Now that I see the screws, it doesn't look all that difficult.  Thanks for the help!
