Author Topic: J code Water Pump  (Read 3289 times)
J code Water Pump
« on: November 10, 2013, 10:37:14 AM »
I have two water pumps a C8OE-A and a C8OE-D. It had the -D on it but can not be sure if it was original. Which would be more correct on a 284-J-01 engine? The body build date was 12-02-67.
Re: J code Water Pump
« Reply #1 on: November 10, 2013, 10:54:11 PM »
C8OE-A . Post a picture of the C8OE-D if you would.
« Reply #2 on: November 11, 2013, 10:15:44 PM »
The first picture is the D that was on the car but not idea if it is original. The second is another D core I have. The third is a restored D that I have. The last is a poor picture of the A. The Ford logo is different on the second.
« Reply #3 on: November 12, 2013, 03:02:41 PM »
I believe there is a distinction in the MPC for the C8-D with the improved design and when it was put into use but can't remember off the top of my head when it wasbut it was later.
« Last Edit: November 12, 2013, 03:13:46 PM by Bob Gaines »
« Reply #4 on: November 12, 2013, 06:42:17 PM »
Marty, is there a chance that the casting number could be C6OE-A?
I have collected 3 small block water pumps and the casting numbers are: C6OE-A, C8OE-D, and C8AE-J. These are the three water pump castings listed in the Mannel book for 1968.
Offline TLea
« Reply #5 on: November 12, 2013, 08:51:08 PM »
Marty
All the early J codes I've seen have the C8AE J. I know the C8OE D came later and used into 69 but not sure when. I had an unmolested 4/68 J code motor that had a C8AE J
« Reply #6 on: November 13, 2013, 12:11:08 AM »
Well it is a C8AE-A  It looks like I am on the hunt for a C8AE-J. Thanks for your help.
« Reply #7 on: November 13, 2013, 12:28:50 AM »
Would check our Special but could not confirm it was original to the car - too many miles :)
Offline tim_morrison82
    • Click Here for My Project
« Reply #8 on: November 13, 2013, 07:01:56 AM »
of the 4 waterpumps i have accumilated, i have a C6OE-A and a C8AE-J, the other 2 are generic ones... my car came with a replaced engine, although the C6 waterpump and the original dizzy were in the trunk when i bought the car... i was told a C6 would not be correct, so i sources the C8 pump... i am still in 2 minds about it originally coming with the C6 one...
« Reply #9 on: November 15, 2013, 10:13:42 PM »
I read a post today that said that the C8AE-J was AC specific. Has any here hear that. I wonder if it uses a different impeller design? I got lucky today found a C8AE-J that was remanufactured. One more thing crossed of the list.
