Though not specifically "Concours" we all find our self at times needing quick access to the suggested factory torque readings for the more typical car building components. So I thought it would be a good project to put together a group (for ever year or two) of these handy/quick guides in the library.
To that end I don't have access to every year and volume of these. I also thought many of you would like to help out so here is the request
If you have access to a 71, 72 and or a 73 Shop Manual please look up the following fill in the needed info. Please specify if your listing 65 or 66 ratings and if including engine torque ratings engine size since a 6 cylinder will be different from a V8 for example. Some of the following items will not apply - just ignore them - its a generic list for across the classic period
Thanks for the help - once collected I'll assemble and post for the benefit of all members
ENGINE - type -
Ignition timing -
Mains - cap bolts -
Mains - Outer cap bolts -
Rods nuts -
Head bolts -
Rocker arm nuts (if positive stop) -
Valve cover bolts -
Intake bolts - Cast steel -
Intake bolts - Cast aluminum -
Harmonic balancer -
Windage tray bolts -
Oil Pump body to block bolts -
Oil pan/Steel mounting bolts -
Oil filter adapter -
Cam Thrust plate bolts -
Cam sprocket to cam bolt -
Timing cover bolts -
Waterpump bolts -
Thermostat housing bolts -
Fuel pump to engine bolts -
Exhaust manifold bolts -
Spark plugs -
Crankshaft pulley to balancer bolts -
Fan and water pump pulley bolts -
Flywheel bolts - Manual trans -
Flexplate bolts -Automatic trans -
Pressure plate to flywheel bolts -
Bellhousing to engine bolts -
Trans bolts - Top Loader top cover -
Trans bolts - Side case manual cover -
Converter to flexplate nuts -
Engine mounts/insulators to block bolts -
Starter motor bolts - Aluminum bellhousing -
Starter motor bolts - Cast steel bellhousing -
SUSPENSION
Strut rod to frame nuts -
Strut rod to A-arm nuts & bolts -
Idler to body/frame nuts & bolts -
Idler nut to center link -
Tie rod nuts - Inner & outer -
Ball joint nuts - Upper and lower -
Center link to pittman arm nut -
Pittman arm to steering shaft nut -
Lower A-arm to body nuts & bolts -
Coil spring saddle to Upper A-arm nuts -
Upper A-arm to body nuts -
