Author Topic: 1967 S-Code GT fast back spring and brake questions  (Read 2342 times)
Offline newmexicogt
« on: November 05, 2013, 08:04:54 PM »
1967 S-Code GT fast back, 9" limited slip, San Jose, January.
The leaf springs have 7 leaves and the shortest one has this number stamped on it:
C7ZA ???6 AU
?20E6
The question marked stampings are very shallow compared to the others.
Even though I want to install new, correct springs, I am curious if these are correct.  Also, what is the correct number?
Next question, about brakes.
The turned portion of the drums (rear only) are right at 2" but the shoes have only 1.75 of lining.  Should this car have 2" or 1.75 rear brakes?  I need to get new drums, can I get 2" and matching shoes and use the existing backing plate, wheel cylinders, etc?
Re: 1967 S-Code GT fast back spring and brake questions
« Reply #1 on: November 05, 2013, 09:20:56 PM »
First off welcome to the site
Wow all the needed info in the first post ;)    Thanks
C7ZA 5556 AU
?20E6
First you mentioned you have 7 leaves on each side??  If so someone has had these apart and played with them - likely in an effort to fight sagging used/old springs. Sounds like they reused the lower leaf to make them sort of original. Four leaves is "normal"
With that said it does appear that they are not original to your car. Would expect to see C7ZA-5556-AM on the short leaf
Though often listed differently its not unusual for the brake to be listed one size and the shoes to be slightly thinner. Don't think there is a problem. Meaasure the shoe (you've already done) and the drum (old drums) and order the same thing
« Reply #2 on: November 05, 2013, 09:35:54 PM »
I am pretty sure that the rear brake size on the 1967 with 390 was 1-3/4 inches wide.
To go wider, you would need to change backing plates. The KH (Kelsey-Hayes) backing plates are marked with numbers.
70867 - Driver side 1-3/4 inch
70866 - Passenger side 1-3/4 inch
71086 - Driver side 2 inch
71085 - Passenger side 2 inch
« Reply #3 on: November 05, 2013, 11:12:08 PM »
+1 Marty
Offline newmexicogt
« Reply #4 on: November 10, 2013, 10:47:17 AM »
Thanks for the help!  Exactly the information I needed.
Jon
Offline rocnhrse
« Reply #5 on: December 21, 2013, 07:27:17 PM »
took mine apart today 67FB Scode GTA built april 12 67 in SJ, the number I have found is C7ZA 5556ASO4OEC7, right next to that was two paint stripes made with what looks like a one inch brush , one stripe kind of a orangey red and beside that a white stripe  it has a 3:00 gear, no posi  I am almost certain these are original markings hope this helps
67 mustang  GTA  S code fastback  San Jose  April 67
