Author Topic: Master cylinder finish 66 Disc  (Read 10227 times)
Offline MyRed66GT
« on: November 02, 2013, 09:22:01 AM »
What would correct finish for master cylinder be? 66 GT Mustang disc brakes built in San Jose. I've seen most cast iron color with the plated cover. Then again I've heard masters were painted black along with the covers...
« Last Edit: January 20, 2021, 05:05:39 PM by J_Speegle »
Re: Master cylinder finish
« Reply #1 on: November 02, 2013, 06:22:04 PM »
Painted all (body, cap and retaining clips) semi-gloss black before it was installed (painted by the supplier)
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: November 03, 2013, 05:25:17 AM »
+1 to Jeffs comments.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline MyRed66GT
« Reply #3 on: November 03, 2013, 10:22:15 AM »
Thanks!
Offline Richard P.
« Reply #4 on: November 08, 2013, 09:35:24 AM »
I've just received my December 2013 issue of Mustang Monthly (M/M) and there is a article titled Identify Dual-Chamber Master Cylinder Caps. The article deals with concours detailing for 1967-1973 M/C caps. In the article the author (Marcus Anghel) states that " in 1966 Ford decided to start referencing its own brake fluid part number (C6AZ-19542-A) on M/C caps due to concerns about the higher temperatures created by front disc brakes" I sent a e-mail to the author asking if he knew when in 1966 did Ford start doing this. It sounds like he has done some research and I'm hoping to hear back from him.
« Reply #5 on: November 08, 2013, 09:38:13 AM »
Marcus posts on this forum.
« Reply #6 on: November 08, 2013, 07:24:23 PM »
Date listed in the TSB's was March 26th  but the text does not specifically state Mustang though one would believe that it was an across the board change not just one car line. The challenge so far is finding late cars with a decal to support the text
Subject has been discussed here and on other sites a few times -
http://www.concoursmustang.com/forum/index.php?topic=6157.msg35197#msg35197
Offline Richard P.
« Reply #7 on: November 08, 2013, 07:54:35 PM »
In the article the author said that the decal was used on Fords with disc brakes. I've been around  Fords and do remember seeing the decals on the old cars. The reason given by the author for Ford doing this makes a lot of sense. The author states that the 1966 part number carried over into early 1967 Fords with the dual chamber M/C disc brake cars utilizing a different shape sticker than was used on the 1966 single chamber M/C.
« Reply #8 on: November 08, 2013, 08:02:16 PM »
.............The author states that the 1966 part number carried over into early 1967 Fords with the dual chamber M/C disc brake cars utilizing a different shape sticker than was used on the 1966 single chamber M/C.
That's correct. As Charles mentioned Marus posted the basic article here for review before it was submitted
Offline Richard P.
« Reply #9 on: November 08, 2013, 08:15:32 PM »
I must have missed the earlier posting.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #10 on: November 08, 2013, 09:29:30 PM »
Richard I must have missed your email, but now see your posting here.  I try to keep up with the forums when I have extra time.
To answer your question, I don't have an exact date when the C6 fluid was introduced only that general time.  What Jeff added here about the TSB would be a good reference but cant say exactly when things were done.
Marcus Anghel
www.anghelrestorations.com
Offline Richard P.
« Reply #11 on: November 08, 2013, 11:47:13 PM »
Thanks for your reply Marcus. I sent the e-mail through M/M so maybe you haven't received it. I enjoyed reading your article. It makes a lot of sense.
« Reply #12 on: November 09, 2013, 12:33:50 AM »
Ok, that's why.  Probably easiest to contact me thru these forums or thru my website directly.
Glad the article made sense.  Working on several more right now.
Marcus Anghel
Offline MyRed66GT
« Reply #13 on: November 09, 2013, 10:05:40 AM »
Second question...does the decal that was on the cover go on after paint? I'm assuming yes but wanted to check to make sure.
« Reply #14 on: November 09, 2013, 07:13:44 PM »
Yes, paint first then the sticker was put on.  Plus its easier that way....
Marcus Anghel
