Author Topic: Pinch weld black out on rocker 1964 1/2  (Read 2494 times)
Offline Hipo giddyup
« on: October 25, 2013, 12:46:18 PM »
 I was wondering how best to duplicate the rocker panel pinch weld blackout on my 64 1/2 coupe. I have heard it could have been brushed-on or sprayed? My car did not come with rocker moldings, does that make a difference? What would be the best technigue and what paint would best duplicate this, semi- gloss, satin, etc.?? Thanks!
Offline mjd 65
Re: Pinch weld black out on rocker 1964 1/2
« Reply #1 on: October 25, 2013, 07:31:09 PM »
There is some good information in this thread.
http://www.concoursmustang.com/forum/index.php?topic=7264.0
Mel
« Reply #2 on: October 25, 2013, 11:31:01 PM »
Most likely sprayed - believed any found brushed was when they were skipped and the mistake was caught later down th eline
No
Like the factory did. Just after the exterior color as been applied before any additional body panels were installed. Duplicating the overspray and direct coverage found on your original cars or lacking that other cars built at the same time and plant. Applied with a soft outer edge (not a tapped/sharp edge)
Offline Brant
« Reply #3 on: October 26, 2013, 12:42:52 PM »
Here is a June 1964 built HiPo Coupe with original paint.  The pinch weld black out was brushed on.
Here is a May 1964 built Convertible with original paint.  The pinch weld black out was also brushed on.
I would duplicate with a semi-gloss (but not too glossy) black.
« Reply #4 on: October 28, 2013, 12:07:45 PM »
 Thanks for everyone's info on this!! Much appreciated
Offline lscman
« Reply #5 on: July 03, 2014, 12:49:11 PM »
What kind of paint did they use?Was it lacquer or enamel?
« Reply #6 on: July 03, 2014, 01:17:36 PM »
Never tested it but I would guess that the brushed details was likely  lacquer for the shorter drying time reasons
Offline lscman
« Reply #7 on: July 03, 2014, 04:38:12 PM »
That pinch weld black out was under the front fenders also wasn't it?
« Reply #8 on: July 03, 2014, 07:23:06 PM »
Yes, applied before the fenders were hung.
