I am restoring a 69 Mach 1 built in San Jose on Dec 30 1968 and the stripe kit I bought has the MACH 1 in the trunk stripe. If I install this would it still be concourse trailered correct? If not does anyone know if anyone makes the stripe kit without the MACH 1 in the trunk stripe?
Depends on how you look at it. Would it be correct? Likely no based on other examples from same production period and plant
If you show the car with the Mach I in the rear stripe you may or may not be deducted for it just depends on the experience and knowledge of the judges.
So you have to ask yourself, it is your car, how correct or original you want your car and how you will answer when someone asks at a show how come your car has the Mach I cut out in the rear stripe.
Restorations are always about choices. Make a plan from the beginning and stick to it. Changing course later or veering off the path means more work, extra expense often and other issues. Many of us have seen or done this and we want to keep others from repeating the process
