Author Topic: Bench seat and console in a 68  (Read 12239 times)
Offline Cptnkeza
Re: Bench seat and console in a 68
« Reply #30 on: November 14, 2013, 11:11:50 PM »
Apparently the car has been sitting in a barn.... Yes a barn on a farm in Indiana since 79
So 3 paint jobs in 11 years seems extreme
The dark blue paint job on the exterior is pretty bad, flaking off the car revealing the light blue in many places
Inside the trunk lid appears to have the original sticker on the light blue paint, so I think that's the color, guess when I pull the interior it will reveal the color.
Here's a close up of the molding drummingrocks
68 convertible (12/67)  302-4V, C4, power steer, power front disc,  3.0 L.S.D, visibility group, interior decor group, deluxe interior
Dearborn
Offline Cptnkeza
« Reply #31 on: November 15, 2013, 08:47:56 AM »
So I purchased a full console last week
But it doesn't look quiet right to me.
It has the padded top, but spears to be on a 67 frame.
Thoughts?
Dearborn
Offline Cptnkeza
« Reply #32 on: November 15, 2013, 08:51:18 AM »
Door  and underneath
Dearborn
« Reply #33 on: November 15, 2013, 09:40:31 AM »
Your rocker moldings are on upside down. The 67 and 68 console bases are the same, looks like the back of the pad is not tight or pad has damage. I can not tell what is wrong by the pictures.
Offline Cptnkeza
« Reply #34 on: November 15, 2013, 11:14:12 AM »
Shouldn't the pad fit like this picture?
Dearborn
Offline Cptnkeza
« Reply #35 on: November 15, 2013, 06:57:40 PM »
Pulled the console apart just now
Their is this metal plate securing the back seat end of the pad
Dearborn
Offline Cptnkeza
« Reply #36 on: November 15, 2013, 07:01:47 PM »
1st pic
Sits better without metal
2nd pic
But no where to secure the back of pad
The last picture shows the cut outs for a early console inlay
Dearborn
Offline Cptnkeza
« Reply #37 on: November 15, 2013, 09:24:28 PM »
Rupstang
Your spot on!
Was told the bases on 68 and 68 were different
Pretty average to use a piece of Tin plate and self tappers to secure the 68 pad on a 67 base
Dearborn
Offline Paperback Writer
« Reply #38 on: November 15, 2013, 09:52:52 PM »
Keep in mind that the console bases for convertibles were different than the ones used on coupes and fastbacks. Due to the extra bracing used on the convertible floor/transmission tunnel, you'll have to cut away some of the base to make it fit correctly...
1967 390 GTA Convertible
7R03S110###
« Reply #39 on: November 15, 2013, 10:02:48 PM »
Rupstang
Your spot on!
I think you have the right plate but it may be turned up side down. Paperback Writer is right you will need to cut the sides of the console down to fit a convertible.
« Reply #40 on: November 16, 2013, 04:31:04 PM »
For reference, here are some photos of my original (and very brittle) 1967 convertible console...
7R03S110###
Offline Cptnkeza
« Reply #41 on: November 16, 2013, 07:48:05 PM »
Dearborn
Offline Cptnkeza
« Reply #42 on: December 08, 2013, 12:19:37 PM »
Ok guys seats out and look what I found
Tag is dated 12/26/67
My car was built 12/26/67
It reads(I think)
0020-6523-100-1
18Z  D 12 26 67
Or
C8Z0-0503-100-1
1SI D 12 26 67
Tag hard to read
Thought any one?
Dearborn
Offline Cptnkeza
« Reply #43 on: December 08, 2013, 12:50:08 PM »
Inner bolt passanger aft hole, from under car
Dearborn
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #44 on: December 10, 2013, 04:55:28 PM »
67 and 68 Console Bases ARE different and even have different physical C7ZB- or C8ZB- engineering numbers molded on the insides.. That is definitely a 68 pad on a 67 base. The metal bracket on rear is the factory rear bracket for the 68 pad and was obviously used to secure the rear of the pad to a 67 base which was not provisioned for an upper trim pad, hence the odd fitment of the rear of the pad..
