Author Topic: steering column spacers  (Read 867 times)
Offline redmach69
« on: October 10, 2013, 06:08:49 PM »
Hey guys, I was wondering on my Mach 1 could I remove the 1 set of additional spacers between the steering column and the dash? If I did so, it sure would be easier to get in and out (not as thin as I used to be) but would it mean the instrument cluster, or the lower dash cover, or the rubber trim piece would then not fit?
Thanks.
Re: steering column spacers
« Reply #1 on: October 10, 2013, 06:54:29 PM »
the rubber donut column seal is different between fastback & coupe &vert & 2 alum spacers verses 1.
« Reply #2 on: October 10, 2013, 08:35:34 PM »
Yes you can remove one of the two (each side) spacers but as Ed mentioned you'll need to get a new donut to better cover the gap created. This will tilt the steering wheel more skyward and change the angle of the wheel to driver.
